Author Topic: 200mm flywheel on 210mm clutch disc..Possible?  (Read 5327 times)
November 22, 2008, 09:08:01 am
Torchd
  • 372
« on: November 22, 2008, 09:08:01 am »
Hey guys!
I have 210mm Act stage three race spec clutch kit but i dont have the 210mm flywheel. Would it be possible to use the 200mm flywheel? like geting it machined or sumthing?
Will i have to get it balanced?
Appreciate the help.
Reply #1November 22, 2008, 10:32:25 am
« Reply #1 on: November 22, 2008, 10:32:25 am »
theoretically if you remove the same amount all the way around, it should stay balanced...
Reply #2November 22, 2008, 11:25:55 am
AudiVWguy
« Reply #2 on: November 22, 2008, 11:25:55 am »
What do you have done to the motor? We need more info.
Reply #3November 22, 2008, 11:36:27 am
vanagonturbo
  • 639
    • Fine Tuning
« Reply #3 on: November 22, 2008, 11:36:27 am »
IIRC the ACT clutch disks are 200mm. Measure it. If its 200mm then you will have no problem.
Reply #4November 22, 2008, 10:40:15 pm
  • 2932
« Reply #4 on: November 22, 2008, 10:40:15 pm »
Been awhile since I did a clutch,..
 The 210mm flywheels have 9 bolts right?
 It seems like the 200mm flywheel uses 6 bolts to hold it to the pressure plate.
 It also seems like the 200mm disc fit pretty tight in the flywheel,... close to the bolts,... a 210 clutch disc might cut the bolts.
Reply #5November 23, 2008, 04:34:35 pm
AdAm84
« Reply #5 on: November 23, 2008, 04:34:35 pm »
could you use a 210mm flywheel on our engines?
Reply #6November 23, 2008, 07:28:57 pm
vanagonturbo
  • 639
    • Fine Tuning
« Reply #6 on: November 23, 2008, 07:28:57 pm »
yes. you will need a 210mm pressure plate too though. dont do it unless you are applying some serious power though.
Reply #7November 24, 2008, 12:23:14 am
  • 2932
« Reply #7 on: November 24, 2008, 12:23:14 am »
The timing marks on some of the gasser flywheels might not be in the right place for diesels.
Reply #8November 24, 2008, 07:03:42 am
« Reply #8 on: November 24, 2008, 07:03:42 am »
Quote from: "fatmobile"
This is true...
Yes you can use a 210mm flywheel/pressure plate combo on our engines. Several people including myself are running the 210mm combo.
I'm running a Clutchnet 8 puck ceramic disk with a SACHS Super Clutch pressure plate and a lightened flywheel.
I can slip it @ freeway speeds under heavy boost so I'll be changing it to a 6 puck set up like 53 willys is running.
Reply #9November 24, 2008, 05:46:11 pm
cyrus #1
  • 360
« Reply #9 on: November 24, 2008, 05:46:11 pm »
How does the Sachs Super pressure plate compare to the clutchnet red pressure plate?
Cody
2002 Jetta TDI
2000 Jetta TDI - R.I.P.
Reply #10November 24, 2008, 06:07:27 pm
« Reply #10 on: November 24, 2008, 06:07:27 pm »
I don't think it's as good and I'll be getting The Red when its time for a replacement.
For all I know it's just paint  :x
Reply #11November 24, 2008, 06:14:25 pm
EcoMod
  • 44
« Reply #11 on: November 24, 2008, 06:14:25 pm »
Hopefully the clutchnet cover has a relocated pivot for the heat treated diaphragm. :?:
Usually that is all that is done to improve clamp force.
Have you tried a 4 puck? not as traffic friendly as the 6 tho.
1992 Jetta EcoDiesel (red)
2001 7.3L Excursion
1993 VR6 5spd B3 Wagon
Reply #12November 24, 2008, 06:17:16 pm
« Reply #12 on: November 24, 2008, 06:17:16 pm »
Quote from: "EcoMod"
No I wont be trying the 4 puck, I don't believe they make it with a sprung hub.
The 6 puck will hold more then we can produce I'm betting. The 8 puck I have now does pretty dang good once it's warmed up.
Reply #13November 24, 2008, 07:00:25 pm
EcoMod
  • 44
« Reply #13 on: November 24, 2008, 07:00:25 pm »
[/quote]
The 6 puck will hold more then we can produce I'm betting. The 8 puck I have now does pretty dang good once it's warmed up.[/quote]
There is a 3-4 puck sprung hub....maybe not clutchnet though.  I have run so many different types of clutches over the years.....
Tried double diaphrams with stock discs, stock pressure plates with 3 pucks even was a dealer for Competition clutch and clutchmaster....I hate the stiff PPlates, they tear up thrust bearings...and my L knee
2001 7.3L Excursion
Reply #14November 24, 2008, 07:29:27 pm
cyrus #1
  • 360
« Reply #14 on: November 24, 2008, 07:29:27 pm »
It looks as if clutchnet has both 3 and 4 puck sprung discs.
http://www.clutchnet.com/product.php?productid=16138&cat=0&page=1
http://www.clutchnet.com/product.php?productid=17159&cat=0&page=1
What sort of pressure plates do you prefer?  I know the 16v PP is supposed to be stiffer than the 8v but most people claim there's virtually no difference in pedal stiffness.
Cody
2002 Jetta TDI
