1.9 tD into a Vanagon
Topic: 1.9 tD into a Vanagon (Read 4146 times)
March 03, 2008, 03:36:03 pm
dokarex
March 03, 2008, 03:36:03 pm »
Hi
Finally found a 1.9TD to replace my 1.6NA in my Doka.
Couple of Questions
1) have to switch oil pans: should I order the 1.9 one or the 1.6 gasket
2) can I run the alt and water pump off the same belt and be rid of the serpentine belt? (no ps or ac) Just switch the pulleys from on engine to the other??
1987 1.9TD Doka from Germany gasser DU tranny, fuel turned up, 1.6 LDA pin, boost at 15 psi,egt and boost gauges,stock diesel tach,air filter behind passenger tail light, IC to come
2005 Jetta Wagen TDI
B6200 Kubota Diesel
16ft Freestyle catermeran
16ft Sunray 85HP
March 05, 2008, 09:27:32 am
myke_w
March 05, 2008, 09:27:32 am »
you need a Vanagon oil pump and pan, the motor lays over so far that a regular oil pump wont work.
you also need the to consider the turbo arrangement, manifold selection, drain lines, injector pump clearance, exhaust mods intake route with filter and intercooler, and on and on..
March 05, 2008, 01:06:50 pm
dokarex
March 05, 2008, 01:06:50 pm »
The van has the 1.6na in there now (has oil pan)
no IP clearance its a Doka
B6200 Kubota Diesel
16ft Sunray 85HP
March 05, 2008, 02:06:32 pm
myke_w
March 05, 2008, 02:06:32 pm »
doh!
well on the oil pan you'll have to have a return line bung welded in..
March 05, 2008, 04:06:03 pm
dokarex
March 05, 2008, 04:06:03 pm »
If you don't mine could you explain the return line? From the turbo?
No inter cooler (yet).
B6200 Kubota Diesel
16ft Sunray 85HP
March 16, 2008, 03:35:06 pm
dokarex
March 16, 2008, 03:35:06 pm »
Hey myke
could you expand on this"well on the oil pan you'll have to have a return line bung welded in.."
thanks
B6200 Kubota Diesel
16ft Sunray 85HP
March 17, 2008, 03:57:41 am
dokarex
March 17, 2008, 03:57:41 am »
anything else?
B6200 Kubota Diesel
16ft Sunray 85HP
March 19, 2008, 06:29:24 am
dokarex
March 19, 2008, 06:29:24 am »
So I have to:
Switch pulleys from 1.6 to 1.9 to drive alt and water pump
Switch oil pan and oil pump
New drain line from turbo to oil pan
Switch pressure plate
Make exhaust and air intake/filter fit
Match up wiring
B6200 Kubota Diesel
16ft Sunray 85HP
March 19, 2008, 06:46:32 am
dokarex
March 19, 2008, 06:46:32 am »
Can I switch the oil pick up tube or do I have to switch the whole oil pump?
B6200 Kubota Diesel
16ft Sunray 85HP
