Author Topic: Oil coming out dipstick?  (Read 3942 times)
March 23, 2008, 01:48:16 pm
stuvy
  • 21
« on: March 23, 2008, 01:48:16 pm »
I have an 89 NA diesel and the only oil leak on the car is coming from the dipstick. I replace the oring on it and it just pushes the dipstick up and poors oil out of the tube. Whats the best way of getting this to stop. Sorry if its a stupid question, but I am a diesel noob.
Reply #1March 23, 2008, 03:17:22 pm
diesel smoke
  • 209
« Reply #1 on: March 23, 2008, 03:17:22 pm »
I don't know too much about n/a diesels but there should be a bolt holding the dip stick tube in place. When I bought my '89 the seal/o-ring was missing there too, so I did a bit of a hillbilly fix and put 2 o-rings on and put a few wraps of electrical tape around the tube just below the ridge, over the o-rings and just above the rings. Then I shoved the whole assembly back into the hole, which was rather tight, put the bolt back and it sealed rather well. 23,000KM later and still no leaks! :lol:  :)
EDIT: Disregard my original post, I thought that the whole assembly, including the tube, came out...
'99.5 Bora TDI
'88 Fox Coupe
'71 Tin Top Westfalia Bus
'85 Mercedes 300SD
Reply #2March 23, 2008, 06:40:19 pm
subsonic
  • 1836
« Reply #2 on: March 23, 2008, 06:40:19 pm »
If you seal it up correctly, and it is bolted in, and you still have oil coming out, time for a compression check.
Reply #3March 23, 2008, 06:41:24 pm
« Reply #3 on: March 23, 2008, 06:41:24 pm »
If you mean that it is coming out of the top of the tube then you most likely have a clogged crank case vent screen. It's the donut looking thing on the valve cover.
Reply #4March 23, 2008, 06:47:27 pm
stuvy
  • 21
« Reply #4 on: March 23, 2008, 06:47:27 pm »
Quote from: "burn_your_money"
Yep it pushes the dipstick out of the tube and oil comes out the top. I will look into replaceing the screen. Thanks
Reply #5March 23, 2008, 08:08:04 pm
burnt_servo
  • 278
« Reply #5 on: March 23, 2008, 08:08:04 pm »
is it over filled with oil?
try running it 1/2 way between the 2 lines on the dipstick .
but like was mentioned before , you more than likely have blow by on your rings , and need to do a rebuild on the motor .
1990 jetta , tweaked pump , tweaked turbo , ported head  2.5inch exhaust .
1993 dodge w250 , diesel ... removing the dead moose parts .
Reply #6March 23, 2008, 08:37:10 pm
stuvy
  • 21
« Reply #6 on: March 23, 2008, 08:37:10 pm »
The oil level is fine. It usually ends up being low at this point, as oil continuely comes out the dipstick. There is a hose coming out of the valve cover, is that a valve or a place to relieve some crankcase pressure? I don't want to rebuild the NA pos. Its only there as the td that was originally in the car apparently threw a rod or something (I bought it from a freind).
Reply #7March 23, 2008, 08:48:17 pm
« Reply #7 on: March 23, 2008, 08:48:17 pm »
Good catch Andrew.
Yes that hose going from the valve cover to the intake could be clogged, or the screen inside of the valve cover
