Author Topic: EGT Probe in wastegate plate?  (Read 3262 times)
September 08, 2010, 07:30:44 am
deathhare
  • 74
« on: September 08, 2010, 07:30:44 am »
Wanting to add an EGT now and was wondering if through the wastegate plate on my T3 is a decent place to locate the probe?
Dont recall seeing anyone have one there though.
In case you arent sure where I'm talking about...the arrow is pointing to the plate.
Opinions on this would be great.   :) Thanks
Reply #1September 08, 2010, 10:26:27 am
deathhare
  • 74
Re: EGT Probe in wastegate plate?
« Reply #1 on: September 08, 2010, 10:26:27 am »
I was afraid of something like that.  :(
Not sure what Ill do as there is no damn way Im pulling this turbo.
Such a PITA to install.  :P
Bad idea to drill the manifold now and have the shavings in there eh?
« Last Edit: September 08, 2010, 10:43:11 am by deathhare »
Reply #2September 08, 2010, 10:59:46 am
toywagen
  • 22
« Reply #2 on: September 08, 2010, 10:59:46 am »
If you grease your drill bit and go slowly you'll catch most of the shavings in the grease. Then you can either vacuum the hole or not worry about it as the shavings will be blown out the exhaust. It's softer than you might think to drill and tap the manifold if you are flexible and can get up there. Nice dp flange also.
Reply #3September 08, 2010, 01:19:06 pm
deathhare
  • 74
« Reply #3 on: September 08, 2010, 01:19:06 pm »
Thanks.
Well what I was worried about was the shavings getting blown through the exhaust turbine and doing some damage.
A real concern or just me imagining things?
A related question...I assume these probes need a hole tapped (probably NPT or something) to thread into their location?
« Last Edit: September 08, 2010, 01:21:55 pm by deathhare »
Reply #4September 08, 2010, 01:40:03 pm
rumbling_caddy
  • 80
« Reply #4 on: September 08, 2010, 01:40:03 pm »
   My EGT probe went here.
Reply #5September 08, 2010, 01:43:03 pm
deathhare
  • 74
« Reply #5 on: September 08, 2010, 01:43:03 pm »
Yeah thats about where i was thinking to do it from under the car.
Just want some assurance the small shavings that may blow out the through the turbo wont do any damage.
Reply #6September 22, 2010, 05:45:12 pm
smoken u
  • 231
« Reply #6 on: September 22, 2010, 05:45:12 pm »
nope, no damage, just grease the bit and go slow, and if you have a small magnet to stick in the hole, do that itll attract any other shavings, also a vacum works good too
1990 VW jetta 1.6 td, 2.5" exhaust, no muffler, governor mod 2010 edition, K&N filter. and now 66 hp and 136 ftlbs.
project 1.6 liter in the works  :)
You don't rev a VW diesel, you increase the clatter.
Reply #7September 23, 2010, 01:52:39 pm
« Reply #7 on: September 23, 2010, 01:52:39 pm »
I read an article in Diesel Power the other day where they were talking about EGT probe installation.  They were saying they leave the engine running so the exhaust pressure prevents shavings from getting in there (along with the greased bit).
Reply #8September 24, 2010, 08:40:55 am
« Reply #8 on: September 24, 2010, 08:40:55 am »
you beat me to it!
(about drilling with a running engine)
Reply #9September 25, 2010, 03:25:10 am
« Reply #9 on: September 25, 2010, 03:25:10 am »
i bet having the thermocouple in the wastegate area would work really well but only when the wastegates open
Reply #10September 25, 2010, 08:17:01 am
« Reply #10 on: September 25, 2010, 08:17:01 am »
yea, when there is a flow of gas going by it. but it would still never be accurate.. it needs to see actual pre turbine exhaust.
