Author Topic: k03/ko4 talk  (Read 3969 times)
August 24, 2010, 11:22:25 am
Mozza
  • 81
k03/ko4 talk
« on: August 24, 2010, 11:22:25 am »
Ok i have been wondering about what turbo to go for and as one of these can be made up to bolt straight on I like this idea,
Questions are:- Who is running one of these and what are the results and what would i need to build one using my exsisting k03 from my AAZ,
Cheers and let the banter begin, !
Reply #1August 24, 2010, 12:41:15 pm
  • 3468
    • McScrubbins Body Wash
Re: k03/ko4 talk
« Reply #1 on: August 24, 2010, 12:41:15 pm »
GEE-BEE has a k03/k04
Reply #2August 24, 2010, 07:53:53 pm
GEE-BEE
  • 1604
Re: k03/ko4 talk
« Reply #2 on: August 24, 2010, 07:53:53 pm »
Correct with ceramic coated housings and full balance
Please give Jerry at GPOPSHOP.com a Jingle
Tell him I sent you ....
P.S. Performance is amazing with this , several people have infomed me how quick this truck is
It ate a 3 series BMW the other night to 92 mph, made a new Titan driver cry....
GB
KO4/KO3 Hybrid turbo
Giles Pump OHC
MK1 JETTA DASH
15x6 Le Casletts 195-45-15
Reply #3August 25, 2010, 12:20:58 am
MJF
  • 581
Re: k03/ko4 talk
« Reply #3 on: August 25, 2010, 12:20:58 am »
We need performance numbers. We cant know if that 3 series BMW was 316 or M3.
'74 VW Scirocco TD
'86 Audi 80q 1,9TDic
'01 Audi A6q 2,5TDI
Reply #4August 25, 2010, 03:56:51 am
Mozza
  • 81
Re: k03/ko4 talk
« Reply #4 on: August 25, 2010, 03:56:51 am »
Superb, I will get incontact with him asap!
Reply #5August 25, 2010, 09:26:22 am
blackdogvan
  • 574
Re: k03/ko4 talk
« Reply #5 on: August 25, 2010, 09:26:22 am »
BG's is backwards (not that thats necessarily a bad thing) from the "standard" K03 hybrid that Kerma or Bora sell BTW. I believe his is a Ko4 hot side & K03 cold side, the vendors sell a K03 hot side with K04 cold side guts in a massaged K03 compressor housing. BG's will flow better at higher RPM while the other will have less lag. I believe they have a very similar shaft & bearing sizes in both.
1991 Vanagon 1.9 mTDI
Reply #6August 25, 2010, 10:09:21 am
GEE-BEE
  • 1604
Re: k03/ko4 talk
« Reply #6 on: August 25, 2010, 10:09:21 am »
That's GB
if it was BG I could sing....
K04 hot/Ko3 cold is correct
Gee-Bee
Was 915.00 with all the stuff done, housings, balance
I sent three cores and i got a 150.00 credit
it was a business expense ( truck) full write off....
Giles Pump OHC
MK1 JETTA DASH
Reply #7August 25, 2010, 10:41:29 am
  • 3468
Re: k03/ko4 talk
« Reply #7 on: August 25, 2010, 10:41:29 am »
So what pressure do you limit that hybrid to?
Reply #8August 25, 2010, 11:55:38 am
GEE-BEE
  • 1604
Re: k03/ko4 talk
« Reply #8 on: August 25, 2010, 11:55:38 am »
Iam at 22psi, until IC
GB
Giles Pump OHC
MK1 JETTA DASH
Reply #9September 02, 2010, 05:08:19 pm
Mozza
  • 81
Re: k03/ko4 talk
« Reply #9 on: September 02, 2010, 05:08:19 pm »
is the build of this sory of hybris domething you could do your self if so what would be involved!
Reply #10September 03, 2010, 05:56:36 am
gldgti
  • 488
    • http://scramjetsite.8m.com
Re: k03/ko4 talk
« Reply #10 on: September 03, 2010, 05:56:36 am »
In my bud's M-tdi build, we got a prothe K04 and I bought a genuine k04 meant for an isuzu i think. the genuine one had all the wrong housings but basically we used the prothe housings with the genuine core. all we needed to do was space out the exhaust housing 0.9mm from the core.
this diesel k04 is certainly heaps smaller than a gasser k04 but it seemed to be a great size for the 1.9. cold side pretty similar to k14, but with larger inducer diameter, and hot side also similar to k14 but maybe slightly larger exducer diameter.... i forget now. Anyway, spooled pretty well but we never got to test it very well because he sold it before we could really tune it up.
'91 Golf Cabrio 1.9TD
