Author Topic: Holset HX35 ! Who has made one work on their setup  (Read 10840 times)
March 26, 2007, 07:57:51 pm
subsonic
  • 1836
« on: March 26, 2007, 07:57:51 pm »
What could a person do with a Holset HX35 w/a 9cm exhaust if they happened to be able to get their hands on one?  :twisted:  Hybrid setup possibilities? I have a stock t3 and a stock k24 to play with.  Will a Giles pump, Ported 1.9 head and Daves exhaust setup, manifold and downpipe out a 2.5" create enough flow to turn a big honk'n turbo like this?  What would you need to do to get the boost on befor the rpm's are way high? Just considering the possibilities.
Reply #1March 26, 2007, 09:36:15 pm
DVST8R
  • 535
« Reply #1 on: March 26, 2007, 09:36:15 pm »
Well from what Andy has reported, you will not see decent boost till 4000-4500rpm. So yes you can make it work, you just have to be willing to make some revs, and dump a ton of fuel in.
The Brett of the board...
The Dark Side of Beauty.[/i]
Reply #2March 27, 2007, 12:21:10 pm
mdonau
  • 53
« Reply #2 on: March 27, 2007, 12:21:10 pm »
hi..
get am Mercedes 3,0L 24Valve  Diesel for that hx35 ;)
else t3 or k24 are fine for a 1,9
greets, Michael
Audi 80 1,6TD:
http://rapsdb.rapsinfo.de/detail.php?id=1807
1,9l TD conversion done!
Reply #3March 27, 2007, 12:29:00 pm
Audi80
« Reply #3 on: March 27, 2007, 12:29:00 pm »
hi..
Too small for Merc, HX40 or HX50 would be enough  :D
I´m going to test a Schwitzer S2B in Scirocco, it is a bit smaller than HX35. I am also dumping TONs of fuel and revving it HIGH  :lol:
Reply #4March 27, 2007, 05:52:48 pm
subsonic
  • 1836
« Reply #4 on: March 27, 2007, 05:52:48 pm »
Wow, that must be some Mercedes!  Can the hot side be changed to allow for faster spool?  If so, what size/ part would you reccomend?  If I use either the t3 or the k24 I think I will go past the good performance envelope of the turbo, and raise the EGT's to much. Besides the swap of the Mercedes .48 hot side, are there other options?
Reply #5March 28, 2007, 08:29:35 am
Benjamin
  • 485
« Reply #5 on: March 28, 2007, 08:29:35 am »
Quote from: "Audi80"
hi..
i think reving it high with rons of tons of feul result in a plunger failure.
a 11mm plunger can not take +5000rpm for to long.
Greetz, Benjamin
Must make +250hp
Reply #6March 28, 2007, 10:38:32 am
Audi80
« Reply #6 on: March 28, 2007, 10:38:32 am »
Greetz, Benjamin
But 12mm pump will :shock:
Reply #7March 28, 2007, 11:59:21 am
Benjamin
  • 485
« Reply #7 on: March 28, 2007, 11:59:21 am »
Greetz, Benjamin
lots of  :?:  :?:  :?:  for me.  :P
my friend broke his 11mm plunger when he was driving 5500rpm in 5th gear for 2km.
i think named tintin was also not running very much rpm with his two 12mm plungers.
so, how much rpm do you think you can run audi80?
Greetz, Benjamin
Must make +250hp
Reply #8March 28, 2007, 12:09:10 pm
Audi80
« Reply #8 on: March 28, 2007, 12:09:10 pm »
Greetz, Benjamin
6000+rpm
2km at 5500rpm :shock:  :shock: Why? I can´t drive 2km at 230-240km/h anywhere :? Also this is IDI, not TDI.
Reply #9March 28, 2007, 12:46:16 pm
zaprzal
  • 160
    • turbodiesel.pl
« Reply #9 on: March 28, 2007, 12:46:16 pm »
I think named tintin had m-tdi... On IDI it's a bit different - you can rev higher
1.6td 170hp 290nm powered by Holset - sold
golf mk2 1.9tdi PD 193hp/400nm ;)
Reply #10March 28, 2007, 04:56:00 pm
Darkness_is_spreading
  • 288
« Reply #10 on: March 28, 2007, 04:56:00 pm »
Yeah  definetly IDI  5500 RPM  the M-TDI  is a 1.9 remember,  much heavier internals but the pump allows for crazy fueling which is wicked sick.
92 Jetta 1.6 T (Sleepin)
Reply #11March 28, 2007, 06:08:12 pm
« Reply #11 on: March 28, 2007, 06:08:12 pm »
well the TDI injection pressures are around 250 bar right??? IDI is only about 155 bar... you can just imagine how much stress is on the plunger at 250 bar...  way up top in the revs the stress must be so great that yes... it would shatter!  but on a lower pressure IDI there is much more potential for high rpm's.  isn't malone revving to 6000 rpm on his Giles super pump???  :twisted:
its a trade-off really... high rpm power or low rpm torque.  i'd personally prefer an m-TDI because high rpm just sucks back fuel... all out race applications would want high rpm though.
Reply #12March 28, 2007, 06:31:24 pm
SMOKEYDUB
  • 630
« Reply #12 on: March 28, 2007, 06:31:24 pm »
malone only has a 9mm pump the last time he ran his idi. I have a 12mm and i rev the snot out of min religously and i hit 5800 rpm? roughly...
12mm PUMP 'O' DEATH on a 1.6L
(courtesy of GILES)
2000 NISSAN XTERRA (5 SPD)
1984 RABBIT TD 2dr (SOLD)
1.8t AEB soon around 550 whp
Reply #13March 28, 2007, 08:11:28 pm
Audi80
« Reply #13 on: March 28, 2007, 08:11:28 pm »
My pump is locally custom made, it will rev ~6000 with full fueling :wink:
Reply #14March 29, 2007, 05:38:27 am
scopefrfd
  • 289
« Reply #14 on: March 29, 2007, 05:38:27 am »
I lost an 11mm bosch pump head..over reving it..When I took it apart I noticed the plunger springs were much stronger.
A possible solution...would be to use 10mm springs on an 11mm or 12mm pump head for high reving.  It would lessen stress on the pump head and I doubt the plunger would "float"
