Author Topic: Manifold question  (Read 4079 times)
March 13, 2007, 12:58:12 am
zagarus
  • 619
Manifold question
« on: March 13, 2007, 12:58:12 am »
Does the piece (circled) rotate 180 degrees so it is easier for me to mount intercooler piping to it?
i couldnt remember if it does but i just wanted to get a confirmation, and if you have any pointers on taking it off that would be greatly appreciated.
Reply #1March 13, 2007, 04:18:24 am
DA-BRT
  • 140
    • http://Zwalve.eu/
Manifold question
« Reply #1 on: March 13, 2007, 04:18:24 am »
Yes, you can rotate that without any problems.
Reply #2March 13, 2007, 05:19:37 am
somepunk22
  • 79
Manifold question
« Reply #2 on: March 13, 2007, 05:19:37 am »
Anyone know where to get the gasket between the manifold and the elbow?
Reply #3March 13, 2007, 07:29:32 am
DA-BRT
  • 140
    • http://Zwalve.eu/
Manifold question
« Reply #3 on: March 13, 2007, 07:29:32 am »
@Andrew: I've been turning them on 1.6/1.9 engines and both had no problems on clearance after rotating. Can be that I missed something.
Reply #4March 13, 2007, 12:29:59 pm
Manifold question
« Reply #4 on: March 13, 2007, 12:29:59 pm »
euro models are different perhaps?
Reply #5March 13, 2007, 12:44:52 pm
g-spec
  • 289
Manifold question
« Reply #5 on: March 13, 2007, 12:44:52 pm »
I tried turning mine and it seems to be glued....I didnt want to pry too hard since it is aluminum....should i heat it????
Reply #6March 13, 2007, 03:49:22 pm
Black Smokin' Diesel
  • 656
Manifold question
« Reply #6 on: March 13, 2007, 03:49:22 pm »
Quote from: g-spec
Piece of wood+hammer. Don't worry, it won't break.
Reply #7March 14, 2007, 12:54:16 am
DA-BRT
  • 140
    • http://Zwalve.eu/
Manifold question
« Reply #7 on: March 14, 2007, 12:54:16 am »
@Andrew: Can be that they are different. I can't recall that I had the extra material on the side. Thought we had only the elbow.
Reply #8March 26, 2007, 03:25:42 pm
g-spec
  • 289
Manifold question
« Reply #8 on: March 26, 2007, 03:25:42 pm »
I tried turning mine and it turns out that the oil line is right in the way or the inlet!!!! what should I do about it????
thanks, Michal
Reply #9March 27, 2007, 07:53:22 am
g-spec
  • 289
Manifold question
« Reply #9 on: March 27, 2007, 07:53:22 am »
Will it not break the oil line???
The oil line goes right thru the middle of the inlet....I would have to bend it quite a bit!!!
cheers, Michal
