Author Topic: K14 boost adjust???  (Read 4034 times)
March 14, 2007, 09:47:27 pm
DELETED
K14 boost adjust???
« on: March 14, 2007, 09:47:27 pm »
DELETED
Reply #1March 14, 2007, 09:52:10 pm
DELETED
DELETED
« Reply #1 on: March 14, 2007, 09:52:10 pm »
DELETED
Reply #2March 15, 2007, 05:15:57 am
k14
« Reply #2 on: March 15, 2007, 05:15:57 am »
First off, it should be a pressure actuator. If it's hooked to vacuum then there
is your problem. If it's hooked to boost, put a gauge in the line to make sure of how much it's getting. It sounds to me like it isn't getting any. My k-14 wouldn't make more than 9 psi with the screw turned as far as it would go. I had to put an air bleed between the turbo and manifold to get anything higher.
Reply #3March 15, 2007, 07:33:42 am
DELETED
DELETED
« Reply #3 on: March 15, 2007, 07:33:42 am »
DELETED
Reply #4March 15, 2007, 04:29:04 pm
DELETED
« Reply #4 on: March 15, 2007, 04:29:04 pm »
Quote from: libbybapa
Jimfoo, that doesn't sound right at all.  I've seen 18+ psi will a k14 on a 1.6 with just the screw turned in on the wastegate.  The wastegate line isn't connected to the manifold, it's connected to the intake scroll.
Andrew
Sorry, you are correct about the location of the line. Mine is obviously apart in preparation of installing the VNT. Mine however didn't get above 9 psi without a bleed. Guess it has something wrong with it, maybe a broken spring or else I misunderstood the previous owner as he had a bleed on it to increase the boost. Guess I don't want to confuse anyone with mis-information.
Reply #5March 16, 2007, 07:15:59 am
DELETED
DELETED
« Reply #5 on: March 16, 2007, 07:15:59 am »
DELETED
Reply #6March 16, 2007, 01:50:30 pm
g-spec
  • 289
DELETED
« Reply #6 on: March 16, 2007, 01:50:30 pm »
Sent you a PM Mario!!! I would just enjoy it...as long as there isnt too much smoke!!! Let me know if you need a EGT!!! I might be able to get one for you!!!
cheers, Michal
Reply #7March 16, 2007, 06:12:00 pm
DELETED
« Reply #7 on: March 16, 2007, 06:12:00 pm »
Maybe the wastegate is stuck closed.
Reply #8March 19, 2007, 02:59:24 pm
DELETED
DELETED
« Reply #8 on: March 19, 2007, 02:59:24 pm »
DELETED
Reply #9March 22, 2007, 06:04:31 pm
boosted_diesel_84
  • 216
DELETED
« Reply #9 on: March 22, 2007, 06:04:31 pm »
do all of the k14's have that line in the wastegate? because i am wanting to turn up my boost, but i dont recall mine having that, and its only making 9 psi, how do i accually turn it up???
.0020 over block,balanced,blueprinted,8lb flywheel,Stage 2 clutch,ported and ceramic coated head manifolds,turbo,pistons, SS valves, PP 2.5in DP,Intake, 3" ex.GTD nozzles, Built pump, windage tray,36mm pump,ARP Studs.etc.My build thread http://www.vwdiesel.net/forum/index.php?topic=15461.0
Reply #10March 23, 2007, 05:00:35 am
g-spec
  • 289
DELETED
« Reply #10 on: March 23, 2007, 05:00:35 am »
Mario give me a call this weekend....I dont think I'm going snowboarding its gonna be +14!!  :cry:
Not all the K14's have the same style wastegate....there are some that you can adjust differently....there would be a threaded shaft behind the turbo and the wastegate would be attached somewhere closer to the end of it......the closer to the end you move the wastegate the more boost....
I dont know if that makes sense or not....but if someone has a pic im sure it would become more clear!!!
cheers, Michal
Reply #11March 23, 2007, 02:36:37 pm
boosted_diesel_84
  • 216
DELETED
« Reply #11 on: March 23, 2007, 02:36:37 pm »
on mine, in the middle of the wastegate, facing the passenger side fender, there is a threaded shaft w/ a 3mm allen key hole in it, and a nut threaded on the shaft, do i need to crank the allen shaft in? or out to increase boost? and how much? thanks! :D
Reply #12March 24, 2007, 10:41:45 pm
Cheesetoast
  • 285
DELETED
« Reply #12 on: March 24, 2007, 10:41:45 pm »
quit being a pansy, i've been running my k14, 1.9td with tdi intercooler at 20psi for a year and half now, no problems.  when i blow it, time to upgrade.
