Author Topic: 1.6td pump on aaz??  (Read 3375 times)
March 23, 2007, 01:10:43 pm
Jimmy Diesel Junior
  • 64
1.6td pump on aaz??
« on: March 23, 2007, 01:10:43 pm »
Hello all. I realise that this may be bordering on the annoying :D   But.... I want to perform the governer mod to my aaz but am afraid of cabbaging the pump in the process. I have quite a number of 1.6td pumps so i am wondering if i perform the mod to one of those pumps, can i then fit that 1.6 pump to the aaz if it turns out to be a success??? thanks guys
PEACE THROUGH SUPERIOR HORSE POWER
Reply #1March 23, 2007, 01:21:59 pm
Audi80
1.6td pump on aaz??
« Reply #1 on: March 23, 2007, 01:21:59 pm »
1,6 pump will fit to AAZ. You could have to change pump bracket and pulley.
Reply #2March 23, 2007, 11:27:25 pm
Jimmy Diesel Junior
  • 64
1.6td pump on aaz??
« Reply #2 on: March 23, 2007, 11:27:25 pm »
Thanks for reply. Would the 1.6 pump be strong enough for the aaz??
Reply #3March 24, 2007, 04:59:00 am
1.6td pump on aaz??
« Reply #3 on: March 24, 2007, 04:59:00 am »
Quote from: "Jimmy Diesel Junior"
don't they use 1.6 pumps for 1.9 TDI's???  :wink:  granted they use a stronger plunger.... hmmmm
Reply #4March 24, 2007, 01:53:11 pm
Audi80
1.6td pump on aaz??
« Reply #4 on: March 24, 2007, 01:53:11 pm »
Itīll be fine with AAZ, but not wit TDI :shock:
Reply #5March 25, 2007, 05:31:30 am
Jimmy Diesel Junior
  • 64
1.6td pump on aaz??
« Reply #5 on: March 25, 2007, 05:31:30 am »
HUMMMMMM. I think i will go for it and see how i get on :o   Do i need to change pump bracket etc as was stated earlier or will it fit up ok?? Do i need to use the 1.6 or aaz injectors??? Thanks for your help guys  :D
Reply #6March 25, 2007, 06:36:44 am
Jimmy Diesel Junior
  • 64
1.6td pump on aaz??
« Reply #6 on: March 25, 2007, 06:36:44 am »
Reply #7March 27, 2007, 04:16:22 am
jannemann
  • 10
1.6td pump on aaz??
« Reply #7 on: March 27, 2007, 04:16:22 am »
Hallo,
when we wanted to fix a Jx (1,6 td in a 90th VW bus) pump at a AAZ engine, we founded out, that the bolt for the belt wheel is shorter than at a AAZ pump. The frontend of the AAZ-bracket was too thick. So It was neccesary to make it thinner (about 5mm) and the fixing holes were changed into oval long holes. So the whole pump was placed nearer to the belt  and all belt-wheels were absolutely  parallel.
Jan
sorry for my  english  :o)
