Author Topic: doka engine swap  (Read 2129 times)
March 24, 2007, 05:57:28 pm
dokarex
  • 61
doka engine swap
« on: March 24, 2007, 05:57:28 pm »
Would a d24t (Volvo) mate up to the 4 sp tranny in my Doka and would the engine be worth it or should I go for the 1.9TD :oops: ?
1987 1.9TD Doka from Germany gasser DU tranny, fuel turned up, 1.6 LDA pin, boost at 15 psi,egt and boost gauges,stock diesel tach,air filter behind passenger tail light, IC to come
2005 Jetta Wagen TDI
B6200 Kubota Diesel
16ft Freestyle catermeran
16ft Sunray 85HP
Reply #1March 24, 2007, 05:59:54 pm
Turbinepowered
  • 1206
doka engine swap
« Reply #1 on: March 24, 2007, 05:59:54 pm »
Mate up, not without an adapter plate. Then there's the matter of the extra 6" or so of space you'd need just to fit the block in there, no belts involved. [edit] Well, it might mate up, if your present engine is a VW 5-cylinder engine.[/edit]
As to whether or not it's worth it, that's for others to chime in and say.
Reply #2March 24, 2007, 08:33:47 pm
itzdshtz
  • 94
doka engine swap
« Reply #2 on: March 24, 2007, 08:33:47 pm »
You can get the Audi 2.0 TD in there if you use the South African bell housing, but in order to install the 6 cyl you will have to do some serious chopping, the crank pulley, alternator and powersteering pump will stick out of the back.
I would go for the 1.9 TD, it is an easy swap.
1989 Vanagon Westfalia 2.1
1987 Vanagon Syncro Westfalia 2.0 TD
2004 Audi allroad 4.2
1997 Audi A6
1985 Audi 5000 Td
http://vanagonsyncroproject-herman.blogspot.com/
http://picasaweb.google.com/itzdshtz/VanagonSyncroProject02
