View full version: Troubleshooting
  1. Dropped valve? Now what?
  2. Cluster issue.
  3. Is it possible for the pump to be timed 180* out? Internally as well?
  4. 91 Eco diesel no crank and seat belt light on
  5. Questions about my new (to me) 1990 1.6TD
  6. ECOdiesel runs hot
  7. cutting mk1 fender so mk2 td airbox snorkel exits engine bay is no good in rain!
  8. Flywheel question
  9. Transmission missing shift at times
  10. New windage tray is dripping oil on 1.6td, are there different part numbers?
  11. trouble shooting
  12. 91 Eco diesel knock
  13. Mk1 Jetta head light issues
  14. b3 passat ac electrical issue
  15. Replacing lower control arm
  16. 85 1.6td timing belt tracking problem
  17. Mileage issues
  18. Hard line wear?
  19. mk2 alternator pivot bolt size?
  20. 82 truck-black wire with eyelet coming from loom with upshift plugs goes where?
  21. Suspension stiffener setup?
  22. Overheating Paranoia
  23. installed a turbo pump on eco diesel won't start
  24. Please identify this stainless flex down pipe
  25. M-TDI no start after working on pump EDIT: Problem Solved!
  26. Vortex Sucks. You guys will solve this riddle.
  27. what to use to clean the inside of pump
  28. So my 1.6TD is running like a dragster, but not in a good way.
  29. run away questions. 1.6TD
  30. Heat only coming from dash vents, no defrost?
  31. unsolved mysteries. 1.6TD (dies at temp)
  32. One last diesel timing question....
  33. Difference between Inj Pump.. 107 k vs 107 ad?
  34. Throttle shaft indexing idle issues
  35. Electrical Issue, where to start...
  36. best place to get a fuel filter...
  37. Transmission Fluid Level Check From Speedo Cable Hole?
  38. smoke issue 1.6tdq
  39. Steering rack boots
  40. So this happened (ac compressor content)
  41. Project pump question
  42. does water and pure motor oil clog fuel filters?
  43. puddle of water on carpet of caddy
  44. Steering rack lubrication..........What to use?
  45. just to clarify, passat front motor mount does not mate with early mk2
  46. Auto trans Inj. pumps?
  47. Idler pulley behind water pump?? Serviceable Bearing?
  48. Caddy Blower Motor with AC
  49. jetta fuel gauge reads lower than it should (and intro)
  50. PSA: Empi no longer Empi axles..
