Author Topic: Difference between Inj Pump.. 107 k vs 107 ad?  (Read 5033 times)
May 04, 2013, 10:14:50 am
Driggs
  • 14
    • Audi b2 Resource
« on: May 04, 2013, 10:14:50 am »
Hey everyone
Scrambling to get my 1982 audi 4000 with 1.6 na going.. gotta take it for a long drive next weekend.
I picked up a spare motor and injection pump in proper working order, and was hoping to use the pump that came with it, while I sent mine out to giles to get worked on.
Question is are they the same??
Stock Audi one is
068 130 107 k
and the vw one is
068 130 107 ad
Any help is appreciated! I cant seem to find any info online
Thanks
84 Audi 4ksq, 82 Audi 4k diesel, 74 Norton Commando, 81 Kawasaki GPz
Reply #1May 04, 2013, 12:26:30 pm
Re: Difference between Inj Pump.. 107 k vs 107 ad?
« Reply #1 on: May 04, 2013, 12:26:30 pm »
If the throttle cable and  stop solenoid hook up, it will work fine unless it has a different type of cam gear.
Reply #2May 04, 2013, 01:42:58 pm
« Reply #2 on: May 04, 2013, 01:42:58 pm »
The bosch numbers on the pumps might give a clue. Pictures could also help reveal differences.
You can measure the camplate curves on them fairly easily, without taking them apart : http://www.vwdiesel.net/forum/index.php?topic=33196.msg309999#msg309999
Reply #3May 04, 2013, 01:52:57 pm
Driggs
  • 14
    • Audi b2 Resource
« Reply #3 on: May 04, 2013, 01:52:57 pm »
Ok.. same cam gear.. ill give it a shot.. hopefully she runs!
Reply #4May 04, 2013, 01:57:20 pm
Driggs
  • 14
    • Audi b2 Resource
« Reply #4 on: May 04, 2013, 01:57:20 pm »
heres a pic
Reply #5May 04, 2013, 03:55:20 pm
« Reply #5 on: May 04, 2013, 03:55:20 pm »
Well, I can't find any more info (clearly it's a 9mm plunger and a four port), but if there aren't any differences externally, I'd run it just the same.
Reply #6May 04, 2013, 04:48:22 pm
Driggs
  • 14
    • Audi b2 Resource
« Reply #6 on: May 04, 2013, 04:48:22 pm »
thanks... i was told by the wonderful tony hoffman i should be good to go.. no real difference
