Author Topic: cutting mk1 fender so mk2 td airbox snorkel exits engine bay is no good in rain!  (Read 4498 times)
June 25, 2013, 02:45:26 pm
damac
  • 531
I had to post this after I almost killed my car today.  I didn't even think about this until I was forced to pull over.  Thought it could be fuel filter but I had a couple nasty stumbles when stabbing the pedal and just knew it was different.  Got a day of nasty rain out of nowhere in the bay area.  I was able to cheat and flip the lid with zip ties just to get home so I am guessing I didn't do damage?
Box full of water, filter soaked and a puddle of water in the intake where oil usually collects!
I did this to my rabbit one day just because I had the parts and wanted to get it on the road and have been driving it for months like this.  I thought having the inlet exit the engine bay was a good thing and tried to mimic the setup in the 85.
I also planned to revisit the engine later.  Lots of people tell me I should intercool, etc. to my rebuilt motor which is all stock right now.
1985 turbo diesel jetta
Reply #1June 25, 2013, 05:53:36 pm
It's been a long time since I had  Rabbit... I guess they don't have a plastic wheelhouse.  :(
I recently forgot to replace the raintray in a parts Jetta, filled the passenger footwells via the AC airbox in one night. XD
Reply #2June 25, 2013, 06:04:54 pm
m b3 w/inner fenders... cone filter up behind headlight.. bent rod going thru silly no water puddle vs the ones i hit over and over 2 hr prior... and im serious.. it was no water.. just a stream/flow across tilted pavemnt.. like garden hose amount... kid ya not.. bent rod...
Reply #3June 25, 2013, 08:11:26 pm
How do you know you didn't bend it before?? lol. Were you in the crank case when it happened? ;)
DAMAC, If it still starts and runs fine.. I'd say you got LUCKY BRO! Good idea, poor execution is all. The mk1's do have an inner fender, but the water is not 100% blocked by it I do not believe.
Reply #4June 25, 2013, 09:31:47 pm
when your great running drops a hole... and smokes like weedwacker... it pretty easy to go.. wow.. that stalled my engine... and now its a 3 banger... happened at my fav stopsign... .5 mile from home... i limped it that last half mile...
this was monday/tues of katerna hurrican that flooded the dome all them years back.. the water puddles i hit prior in the evening should have done damage this peeazly little stream caused...
rod hangs on my wall... pull head was easy to see the "stroked bore"..
Reply #5June 25, 2013, 09:52:05 pm
damac
  • 531
I totally knew better, I can't understand why I even started the car.  I do some really stupid things sometimes when I get tired.
With the airbox bottom flipped I had to zip tie it closed, but it made it 90 miles home in the rain.  Not allot of water splashes up to the timing belt cover I guess.
Drove it hard as ever without a stumble and could hear the turbo again.
I could drive my old f250 in the rain all day with the cowl intake.  That bastard was loud, but I guess its because with the drains clear that area could take allot of water in and not be high enough to spill over into the intake tube.
