Author Topic: Cluster issue.  (Read 4992 times)
July 14, 2013, 01:03:33 pm
One_punchmachinegun
  • 261
Cluster issue.
« on: July 14, 2013, 01:03:33 pm »
Hey guys,
 The issue is that I gutted the car to clean it up. Now I am in the process of putting everything back. So far I have sorted the wiring to be a little more neat(PO tried to put a "sound system" in it and was careless). I also now have re-installed the dash and plugging everything back in. I started with the cluster, but when I plugged it in I want to make sure all was well.. I wasn't. The cluster is getting power but isn't lighting up any of the dumby lights(oil,coolant,glowplugs,tach ect.)I know the cluster is getting power since the clock turns on and counts. I double checked everything and all seems well. I also tried another cluster  with the same results..
Please let me know what you think.
“If anyone hears my words but does not keep them, I do not judge that person. For I did not come to judge the world, but to save the world." Jesus Christ
Reply #1July 14, 2013, 11:58:13 pm
mystery3
  • 774
Re: Cluster issue.
« Reply #1 on: July 14, 2013, 11:58:13 pm »
MkII? What kind of cluster? I know nothing of mkII's but that info may help others.
Reply #2July 15, 2013, 06:23:16 am
srgtlord
  • 797
Re: Cluster issue.
« Reply #2 on: July 15, 2013, 06:23:16 am »
Hmm if I was having this issue I would look at the wiring diagram  for the input and power going into the cluster and take out the Ol' voltemeter to be positive that voltage was truly being passed to the cluster
Reply #3July 15, 2013, 06:34:49 am
Re: Cluster issue.
« Reply #3 on: July 15, 2013, 06:34:49 am »
clock is not same power as lights/gauges so on.. black wire is hot w/key which is what you seek... clock is red or red/white as power all time..
Reply #4July 16, 2013, 10:23:48 am
One_punchmachinegun
  • 261
Re: Re: Cluster issue.
« Reply #4 on: July 16, 2013, 10:23:48 am »
Ok, so I figured out that it was just a fuse. But I looked at the fuse diagram on a2resource and it didn't correspond with with fuse that is said to work with the cluster.  I don't know why that is, but I Thank you guys for your help, still learned from your post.
Sorry for the stupid post.
Reply #5July 16, 2013, 10:27:52 am
Re: Cluster issue.
« Reply #5 on: July 16, 2013, 10:27:52 am »
but i can see a idiot using cluster wires for radio... so not stupid.. why i told wire colors to look for...
