General Information
» Troubleshooting
View full version:
Troubleshooting
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
Fuel Shutoff Solenoid question
Can thickness of head gasket contribute to no start?
1980 VW Rabbit diesel electrical problems
hard starting, glow plugs working...
Bad front shock?
First winter woes in '85 jetta 1.6d
Glow plug light comes on while driving
dial gauge conversions
84 Rabbit Diesel Swap
1.6L diesel solid to hydraulic head conversion
cam photo and a couple of questions
Fast idle
water pump replacement?
2000 TDI - No Power + Hard Starting
Lucas calipers on a golf 2 which master cylinder???- Help
Mileage going wrong way
Oil Pumps out Dipstick tube
car sitting for 18 months
Blowing heater cores
D24 Volvo .. no fuel to filter?
Strange Problem No Start-Fuel or Oil?
Idiot needs help
Priming injectors
Emergency Brake won't click up anymore??
compression test results
[TDI 1Z]troubles-DONE-
Jetta Diesel trans vs Gas
Head gasket finally done for?
I think I fried my tach - can I tell for sure?
Uh-oh! Snapped timing belt.
squealing and tach not working, please help!
leaky IP help needed
IP on 93 1.9 td Questions
Noisy PD
jetta wont start
TDI automatic transmission burning smell
Leaky Injector Pump
Replace Pump seals in Ottawa
Odd brake vacuum issues
1.6 non-turbo has mean rough idle
anybody know how to replace the heater blower??
Power steering pump seizing up?
Worn Rings
i did see that
Is the Bosch DGK 126 REALLY made of Viton ?????
How soon should I have valves adjusted after rebuild?
Any suggestions on checking valve clearances?
Leaking Injector Body
Looking for the #1 cylinder
Howdy and a question
