View full version: Troubleshooting
  1. Post re-seal question
  2. air pump solenoid valve
  3. turbo piston cooling
  4. I broke an 11mm ARP stud
  5. Hard start when cold
  6. 85 VW NA 1.6 Diesel won't run above idle at full throttle
  7. Juddering on tickover.
  8. Is this just my 1.9/1.6's low compression at play?
  9. Serpentine tensioner
  10. Tag lights
  11. How embarassing...My delivery valve is showing
  12. Weird TDi pump timing issue , long post
  13. removing the HVAC box - need help
  14. 96 Jetta Diesel Cruise not working? warm car up w/o alarm on doors going off?
  15. Idle smoke?
  16. Proper Way on Changing Fuel Filter 1.9 Diesel Jetta?
  17. Rear washer
  18. A1 pump lever question
  19. ...CRANK, NO START ISSUE....
  20. Timing Mark off?
  21. 81 Caddy rad fan problem
  22. No start issue.
  23. Factory installed 72C thermostat???
  24. Sleeping speedo
  25. Crankshaft Pulley Issues
  26. crank sprocket
  27. power steering
  28. AAZ IP Pump...Can anyone answer?
  29. Really odd behavior on long drive.
  30. 1.6 died warming up, won't restart
  31. Exhaust smell in car
  32. I got a starting concern
  33. 81 rabbit diesel 5spd
  34. BACK TO SQUARE ONE.
  35. Oil and coolant consumption, pressurized exp.tank
  36. Cold start on recently rebuilt pump?
  37. Automatic in my 2001 Jetta lost forward gears need help
  38. 1990 JX engine. Oil light flashes when engine warms up
  39. IP pressure Dynamic / static timing help please
  40. Leak around cold start lever. CY engine
  41. Idle Adjust..pic
  42. Injector pump "loses it's prime"
  43. Injector Pump Sprocket...Strange Pic?
  44. What thread size in '90's master cylinder?
  45. squeak, squeak, squeak
  46. noisy all of a sudden
  47. How do I check my Glowplugs to see if they are working?? Car won't start in cold
  48. Brazilian Diesel Engine...Parts?
  49. no start! help please.
  50. Is Using a MKII tophat with MKIII spring Dangerous??
