View full version: Troubleshooting
  1. bad turbo or worse?
  2. swapping 1.6D for 1.6TD
  3. 1.9 TD Dipstick length HELP!!
  4. kkk03 Turbo woes...
  5. 1.6N/A compatable with LDA pump?
  6. enigne not heating...
  7. alternator problem in 91 jetta 1.9TD
  8. cam pulley
  9. No fuel, bad pump?
  10. Very slow starter, had to push start, works now... WTF?
  11. Emergency ALH triage needed!!!!!!
  12. cooling system pressurizing?
  13. AAZ motor issues...
  14. Crankshaft bolts on 1.6NA
  15. How to clock turbo exhaust side
  16. Lower Coolant hose almost always cold
  17. Vibro-matic dashboard
  18. Shift gates totally wonky
  19. My car just died
  20. Injection pump.
  21. crank fixed, still wobbles what can I do?
  22. VSP Glow plugs?
  23. Grrrr.....I broke the vacuum pump nipple.
  24. Glow plugs troubleshooting
  25. put on your thinking caps 4 this one,pump guys
  26. Fuel tank problems
  27. Symptoms of bad pump...need urgent advice??
  28. Pully Alignment?
  29. head bolt torque (now i know what a german torque is)
  30. Cold start difficulty questions...
  31. Annoying Noise from the Fusebox >:-(
  32. Injector pump seal kit
  33. Re-use Head?
  34. Coolant expansion bottle?
  35. Alternator question
  36. Learning more about my TD...
  37. Fuel line prob!
  38. 1.9 Diesel Fuel Delivery/Starting Problems
  39. Injection pump tuning
  40. Bad injector symptoms?
  41. got exhaust manifold?
  42. help ball joint let go!
  43. Replacing that li'l fuel supply hose on the tank -
  44. 1qt every 5-600miles from crankcase
  45. smoke smoke smoke
  46. Stuck dipstick tube....HELP!!!
  47. Smoking/rough idle, but drives fine
  48. Leaking Injection Pump :-(
  49. diesel injection pump
  50. injector seat fix??
