View full version: Troubleshooting
  1. Intermitent slow/no starting New problem...
  2. Thermostat or water pump?
  3. 1.6TD TDC with gasser 210mm flywheel???
  4. Need diagram for rear brake drum
  5. LIGHTS on Lights OFF
  6. Looking at Conspiracy Theories...
  7. overspeed
  8. 91 Eco diesel injector question
  9. 91 Eco-Diesel turbo whine??
  10. blowby/oil leak building up on lower ac radiator fan rubber flap(85 jetta)
  11. Glow plug LED dash indicator
  12. Are my pistons damaged too much? Pictures
  13. slow cranking after glowplug replacement?
  14. weird overheating problem??
  15. 91 Jetta EcoDiesel bolt part #
  16. 91 Eco Diesel Jetta issues
  17. 91 Jetta EcoDiesel Tires
  18. 1984 Jetta 1.6 N/A Diesel Problem.
  19. Anyone want to talk VE pumps?
  20. Fuel pump gasket/seal kits?
  21. 91 Jetta Eco Diesel..Which P/N for pump head o ring HELP
  22. Timing Question
  23. driver steering rack stud broke on 79 rabbit, do clamps mount straight up/down?
  24. TDI cold start problem
  25. 1.6D starts, then dies... fueling issue?
  26. 1.6 NA timing belt wear/oil leak/fuel leak
  27. Rabbit is dead again :(
  28. Thermostat
  29. Installed tach cluster and oil warning goes off...
  30. Second head gasket in 1000 miles. Please help!
  31. Eco diesel weird noise at startup possibly valve related Now coolant issue
  32. are 1.6td exhaust studs same size as turbo?
  33. Quieting the IP
  34. Transferring N/A bits onto TD Block
  35. lost pump setting
  36. damned electrical bugs.
  37. Does GKN not sell inner CV boots separately anymore?
  38. A happy medium for idle?
  39. 1.6D cooling/parts questions
  40. Different looking injectors bleeding lots of air into return line
  41. '85 jetta starting issues
  42. New or Remanufactured Axle?
  43. 1984 vw jetta diesel garaged since 1999
  44. Random AAZ pump wires :s
  45. Head gasket replacement becoming can-o-worms.
  46. New Engine Shorting Out the Battery??
  47. Transfer pressure while cranking
  48. Diesel Engine 1.6TD wont start......help!!!
  49. strangest thing just happened... (axle self removal)
  50. Caddy Fuel Sending Unit Upgrade
