Author Topic: Eco diesel weird noise at startup possibly valve related Now coolant issue  (Read 9170 times)
October 20, 2012, 04:18:40 pm
bbob203
  • 1789
« Last Edit: October 22, 2012, 03:57:23 pm by bbob203 »
92 Passat wagon M-TDi
03 Jetta wagon TDi
VE Timing tools for rent
Reply #1October 20, 2012, 04:27:07 pm
Re: Eco diesel weird noise at startup possibly valve related?
« Reply #1 on: October 20, 2012, 04:27:07 pm »
When I start it up it makes this noise otherwise runs good
timing belt tensioner been replaced lately?
starter solenoid disengaging when you let off the key?
Reply #2October 20, 2012, 04:42:20 pm
bbob203
  • 1789
« Reply #2 on: October 20, 2012, 04:42:20 pm »
tensioner newish
03 Jetta wagon TDi
Reply #3October 20, 2012, 05:24:45 pm
« Reply #3 on: October 20, 2012, 05:24:45 pm »
maybe your hydro lifters are starting to tick, just like every other VW with hydro lifters..
does it just make noise for a few seconds, then go away?
Reply #4October 20, 2012, 05:44:33 pm
« Reply #4 on: October 20, 2012, 05:44:33 pm »
Sounds pretty normal and diesely to me.
Reply #5October 20, 2012, 05:54:09 pm
bbob203
  • 1789
« Reply #5 on: October 20, 2012, 05:54:09 pm »
yea its like squeaky duck quaking noise. right at start up then I get a low backround tick when running.
03 Jetta wagon TDi
Reply #6October 20, 2012, 09:22:24 pm
Dakotakid
  • 1240
« Reply #6 on: October 20, 2012, 09:22:24 pm »
ROR has already diagnosed it:  starter slow to kick back out (take it apart and clean it) and worn, crudded up or otherwise lazy lifters.
The starter will get worse in cold weather. Better to deal with it now.
Reply #7October 21, 2012, 01:46:23 am
bbob203
  • 1789
« Reply #7 on: October 21, 2012, 01:46:23 am »
√ and √. Should I be concerned with lifters? any remedy? rebuild the head? gonna be driving a 4 hoir round trip tomorow and a 12 hour round trip wenesday. thanks for the input. this is a noise the specific engine has made since I got it and always thought it was from the ip
03 Jetta wagon TDi
Reply #8October 21, 2012, 09:13:41 am
« Reply #8 on: October 21, 2012, 09:13:41 am »
My 88 1.6TD has a good tick going on, but I am not overly worried about it. It is definitely coming from the engine, but alas if she pops.. Its getting a M-TDI and a Rover pump ;).
What weight oil are you using? I thought this noise was a few seconds after start only? Nearly every hydro vw 4 cyl I have ever worked on will clack the lifters around for a few seconds at start-up based on temperature and weight of oil used.
I have 15w40 conventional in the 88, 5w50 full synthetic in the 84 AAZ, and 0w40 full synthetic in the AHU M-TDI. Out of all of them the AHU has the most km's by about a 125,000 difference on the AAZ.. and it has no lifter ticking. Must have upgraded the design by the time they got to their third diesel engine generation.
Reply #9October 21, 2012, 10:09:58 am
« Reply #9 on: October 21, 2012, 10:09:58 am »
had a feeeling it was the solenoid...
my GTI does the same thing..
solenoid is getting lazy, and probably the bushing getting worn..
Reply #10October 21, 2012, 11:27:34 am
Dakotakid
  • 1240
« Reply #10 on: October 21, 2012, 11:27:34 am »
Ya, my solution to hyd. lifter problems is simply not to rebuild any more hyd. engines. Life is so much better in their absense. I love my newly rebuilt gas digifant block mated to an older GTI Rabbit head. Plus, it runs like a molested chimp.
Reply #11October 21, 2012, 03:18:46 pm
bbob203
  • 1789
« Reply #11 on: October 21, 2012, 03:18:46 pm »
It has a tick when running. But it also has this squeaky duck quack noise for one second at start up(which i thought might be lifters) but now think it is something starter related now that i think more about where the sound is coming from and that you guys mentioned it. Otherwise the sucker runs like a champ. Ip has an air leak somewhere in it but only enough for the backflow on the in flow to get a air bubble in it once i shut it down and it isn't pumping a sporadic burst of bubbles in the out flow. When i get the fuel pump installed it wont be any issue. AND when i get myself a resealed td pump ;D
03 Jetta wagon TDi
Reply #12October 22, 2012, 11:22:56 am
« Reply #12 on: October 22, 2012, 11:22:56 am »
tick when running is lifters..
wait till its about time to change oil, and add 1qt of ATF or MMO in the oil, run it for a week, usually cleanes up the sticky lifter..
Reply #13October 22, 2012, 01:42:56 pm
bbob203
  • 1789
« Reply #13 on: October 22, 2012, 01:42:56 pm »
yea I got some mmo. stuff does wonders in saturn motors. this engine sat dry for a bit in my garage so it might be it.
03 Jetta wagon TDi
Reply #14October 22, 2012, 01:45:30 pm
« Reply #14 on: October 22, 2012, 01:45:30 pm »
oh, definitely, if it sat dry..
have you rally had this engine up to operating temp for more than a few minutes yet?
my Audi GT clattered like no other when i fired it up after sitting, and i thought it had bad lifters..
after i drove it for a week, they got ALOT quieter...
a quart of ATF and another week, and the lifters were SILENT..
