View full version: Troubleshooting
  1. Differences between Mk1 / Mk2 TD pumps?
  2. TD Pump
  3. 1982 VW Pickup electrical issue
  4. Fan upgrade
  5. Speedometer issues
  6. TD Specific Parts?
  7. Leaky throttle shaft
  8. it won't start?
  9. Gov mod cause starting problems?
  10. Fuse 1 blowing
  11. Moment of Inertia question
  12. Injection Pump switch
  13. torque specs 1.9td AAZ
  14. Glow Plug Relay going craaazy
  15. 81 na starter/fan
  16. knockd pin out of pump changing cambelt
  17. 020 Pinion Shaft Contact Inside Case?
  18. serpentine Troubles. Please help.
  19. glow plug testing - AAZ
  20. Clutch Cable for Intercooled TD
  21. head decision
  22. 1.6TD starting issues
  23. Injection pump check valves
  24. Are all Bosch 107A yellow dot pumps?
  25. which head gasket?
  26. ULSD and our cars
  27. Air filter, oops
  28. Car keeps eating ac/waterpump belts. Please help.
  29. How Hot does your car get pulling long steep hills?
  30. Glow plug light kicking off immediately
  31. Do I have pre-heater
  32. AC Bolts
  33. Injection pump problmes
  34. AAZ crank bolt problem?
  35. where to buy Injectors or nozzles?
  36. which head gasket? Help please
  37. Bosch Yellow Dot 107A pump on 1.6L
  38. Motor Removal
  39. 1.6 dipstick length
  40. 2004 Wolfsberg Jetta with 75,000 kilometers
  41. Help getting it started?
  42. 98 Jetta TDI
  43. Bad head gasket?
  44. Oil leaking from my boost controller, HELP!
  45. 90 Jetta 1.6L starting problem
  46. hard to start
  47. engine replacement
  48. what size tool do you use for the head bolts ?
  49. pulling front main oil seal
  50. 1.6 non-AC alternator number
