Author Topic: which head gasket? Help please  (Read 4688 times)
September 14, 2006, 01:31:52 pm
A Guy
« on: September 14, 2006, 01:31:52 pm »
'94 1.9 idi, no air, manual trans.
I need the appropriate head gasket . My parts guy says he has listings for three of them which one do I need? the options are 1 hole, 2 hole or 3 hole. The # of holes corelates the the thickness of the hg.
Any quick help is greatly appreciated.
Out.
Greg
Reply #1September 14, 2006, 05:24:31 pm
bvolks73
  • 183
« Reply #1 on: September 14, 2006, 05:24:31 pm »
I'm not sure about the 1.9 but on my 1.6 I can look between #2 and #3 cylinder and there is a piece of the head gasket sticking out towards the front of the car. That's where the holes (or notches on some) are. Get one with the same # of holes.
1985 TD Jetta coupe
1995 Golf CL
1971 VW Doublecab
1999 Corolla
2005 Sx 2.0
2007 Yaris
Reply #2September 14, 2006, 08:55:47 pm
« Reply #2 on: September 14, 2006, 08:55:47 pm »
it has to do with piston protrusion.  you have to measure it, and get the appropriate thickness hg.  You can go with a 3 notch, but it will be a bit hard starting it in the winter if it actually needs a 2, or even 1.
do a search on notches, and maybe someone has already posted the protrusion measurements and the hg notch required for them.
Reply #3September 19, 2006, 01:38:20 pm
A Guy
« Reply #3 on: September 19, 2006, 01:38:20 pm »
I located the section of gead gasket sticking out between # 2 and #3
It's a three hole.  Holy crap I was blown away at how heavy those head gaskets are!! :shock:
I'm almost back on the raod! thanks again for all the help!!! :D
Out!
