Author Topic: Motor Removal  (Read 5250 times)
September 17, 2006, 07:32:03 am
Darkness_is_spreading
  • 288
Motor Removal
« on: September 17, 2006, 07:32:03 am »
Well I am so close to pulling the motor on my 88 Jetta that I can smell the soot of the better motor.  I'm stuck at trying to remove the Axle 30mm nut from the front drive shaft.   I have never seen such a seized nut in my life, I've heated it up,  shot it with WD 40, used alot of leverage,  massive torque air gun, and still nothing.
Is this nut a reverse thread type,  because I broke a Breaker Bar trying to remove this nut........
92 Jetta 1.6 T (Sleepin)
Reply #1September 17, 2006, 12:07:19 pm
Justin
  • 455
Motor Removal
« Reply #1 on: September 17, 2006, 12:07:19 pm »
Its regular threads, when you heat it up try spraying it with water after you have the nut good and red, that should break up any rust in there.
good luck
www.archeryprostaffmi.com
Reply #2September 17, 2006, 07:59:35 pm
SMOKEYDUB
  • 630
Motor Removal
« Reply #2 on: September 17, 2006, 07:59:35 pm »
i never undo the big nut i just push the inner cv in and the drive shaft falls down... assuming you got the inner cv bolts off the tranny. and you leave the axles in and pull the engine and tranny.
12mm PUMP 'O' DEATH on a 1.6L
(courtesy of GILES)
2000 NISSAN XTERRA (5 SPD)
1984 RABBIT TD 2dr (SOLD)
1.8t AEB soon around 550 whp
Reply #3September 18, 2006, 02:08:46 pm
Motor Removal
« Reply #3 on: September 18, 2006, 02:08:46 pm »
This is what happened last time I removed that bolt
I had my girlfriend stepping on the brakes and me hanging off a 7 foot braker bar (yes 7 feet). I still barely got the stupid thing off. My electic impact sure couldn't get it to budge.
Reply #4September 18, 2006, 02:32:54 pm
bvolks73
  • 183
Motor Removal
« Reply #4 on: September 18, 2006, 02:32:54 pm »
I usually borrow my landlord's 3/4 inch drive power bar and 1-3/16 (I think) socket to take those axle nuts off. I've broken many power bars myself. I agree with smokeydub about not having to take them completely out. I never take them out completely anymore. However, the driver's side one is tricky when you're putting the motor back in.
1985 TD Jetta coupe
1995 Golf CL
1971 VW Doublecab
1999 Corolla
2005 Sx 2.0
2007 Yaris
