Author Topic: glow plug testing - AAZ  (Read 4540 times)
October 05, 2006, 10:12:53 am
iggi
  • 33
« on: October 05, 2006, 10:12:53 am »
Hi,
I'm sure this is buried in the archive somewhere but I couldn't find it.
How do I test the glowplugs?
It's taking a bit to get started on cold mornings and smokes like crazy when first started.
Figure it must be the glow plugs or the perhaps the relay but as I don't have the Bentley Manual yet I'm not sure how to test for the fault.
Any help much appreciated.
Ian
'97 Jetta GL TD
'87 Vanagon Westy
Reply #1October 06, 2006, 07:49:38 am
commuter boy
  • 277
« Reply #1 on: October 06, 2006, 07:49:38 am »
I've always found the easiest thing was to pull the injectors and watch the plugs heat up through the hole when someone turns on the ignition.
I hate fiddling around with the little nuts behind the fuel pump holding the glow plug harness on, and I never had a big enough ammeter to measure the draw on the circuit to test them properly.
$2.00 of new heat shields to go under the injectors afterwards, 10 minutes to pull injectors and re-install, + time to swap out dead plugs.
