Author Topic: which head gasket?  (Read 5622 times)
September 12, 2006, 11:12:59 am
A Guy
which head gasket?
« on: September 12, 2006, 11:12:59 am »
'94 1.9 idi, no air, manual trans.
I need the appropriate head gasket .  My parts guy says he has listings for three of them which one do I need?   the options are 1 hole, 2 hole or 3 hole.  The # of holes corelates the the thickness of the hg.
Any quick help is greatly appreciated.
Out.
Greg
Reply #1October 02, 2006, 09:22:03 am
jstaton
  • 41
which head gasket?
« Reply #1 on: October 02, 2006, 09:22:03 am »
The holes denote the thickness of the gasket material. The easiest way to see what size you need is to look at the front of the motor ( the front being the front of the car) where the head and the block meet. Part of the head gasket sticks out here, you will see 1,2, or 3 holes (not notches) this will tell you what you need.
Reply #2October 02, 2006, 03:13:41 pm
which head gasket?
« Reply #2 on: October 02, 2006, 03:13:41 pm »
I was always under the impression that you had to remove the head to check which HG is required. Maybe it's differant with the 1.9s?
Reply #3October 02, 2006, 06:15:46 pm
coke
  • 254
which head gasket?
« Reply #3 on: October 02, 2006, 06:15:46 pm »
You have to remove the head to get a 100% sure answer. If the gasket that was on it was right, you could just pick up another of the like. But the only way to tell for certain is to pull the head, and measure the piston protrusion above TDC.
