Author Topic: TD Pump  (Read 4546 times)
October 16, 2006, 07:40:09 am
Wills
  • 27
TD Pump
« on: October 16, 2006, 07:40:09 am »
Right, I have a motor from a 1.6td Passat in my Caddy and the pump looks to be knackered, this engine is/was already intercooled, I just picked up a Golf with a TD motor but this engine has no intercooler and the pump is different, it looks like a part on the top is missing at a glance Passat is 89' Golf is 91'. What I need to know is can I intercool this new engine and are there any differences in the pumps both are 1.6
Reply #1October 16, 2006, 11:47:04 am
veeman
  • 421
TD Pump
« Reply #1 on: October 16, 2006, 11:47:04 am »
The one from the Golf is probably from an ecodiesel engine.  The eco's had the turbo, but didn't have the LDA (boost / fuel compensation device) on the pump.   Essentially, the boost made emissions better, but didn't increase power much since the fueling wasn't increased at the same time.
You can intercool any turbo engine that you want... that shouldn't make a difference, but to take advantage of the increased power possible from a TD, you should try to keep the LDA (the thing that looks like a flying saucer on top of the pump).  From what I've heard, you can switch that part onto an eco pump, but I'm not sure how... I've never done it.
81 Caddy TD
98 Audi A4 Quattro V6 TDI
83 VW GTI FSP
86 4ktq
Reply #2October 16, 2006, 12:45:17 pm
Wills
  • 27
TD Pump
« Reply #2 on: October 16, 2006, 12:45:17 pm »
Well thats a better start, so anyone out there know how to swap this over then?
Reply #3October 16, 2006, 12:46:59 pm
Wills
  • 27
TD Pump
« Reply #3 on: October 16, 2006, 12:46:59 pm »
just a thought but would it be alot slower not fitting this?
Reply #4October 16, 2006, 01:10:33 pm
TD Pump
« Reply #4 on: October 16, 2006, 01:10:33 pm »
I think it makes a 10hp differane in stock form. Once you start upgrading though you'll defintly want the LDA. There was recently a post somewhere one here explaing how to put the LDA on a non-LDA pump.
You might be better off just getting a true TD IP and selling the ECO pump
