View full version: Troubleshooting
  1. Too much blowby
  2. Lost the high beams........
  3. Missing at only a certain RPM
  4. Brrr, so cold!
  5. It's time to play...Name...That...Alternator!
  6. '86 golf diesel clicking and white smoke
  7. RIGHT SIDE TURN SIGNALS--REALLY FAST
  8. Reuse 1.6L TB Idler in a Pinch? Time is running out.....
  9. '91 Jetta 1.6 turbo diesel questions (no fuel)
  10. Reman Bosch Starter- No need for bushing?
  11. Fly Wheel Question
  12. Timing Gauge
  13. Did I use the wrong MC?
  14. Any suggestions on retightening belts on 86 1.6L N/A?
  15. rascally rabbit
  16. Speedo and tach shutting off
  17. I'm having just too much fun not!! a tale of heater cores
  18. 1Z engine, does rev counter work off alternator or crank
  19. 1Z tdi engine conversion into mk2 golf, need some help
  20. 6 piece thrust bearing question
  21. headgasket?
  22. 1.6L NA - worth rebuilding?
  23. Roller carrier contacted injector pump housing...Help!
  24. Lots of smoke on cold start
  25. What kind of Head is this ?
  26. New Starter Already Fried?
  27. -35 and car wont start
  28. HELP!! Oil line info needed
  29. Quick question on IP timing procedure
  30. Torque Spec for Alum G60 Valve Cover and Rubber Gasket???
  31. solar panel blowing fuse
  32. Low oil pressure buzzer...Fixed
  33. Oil pan leak
  34. GTD starting issues
  35. mk2 golf diesel conversion, how do i wire up rev counter
  36. help with manualy disengaging the locking gas cap?
  37. can I use a steering pump off another vw for my golf gtd?
  38. Weird glow plug light problem
  39. starting issues
  40. 1.9td aaz? engine staring problem
  41. mk3 td engine in a mk2
  42. overcharging issues on an aaz
  43. For MKII turbo diesels, T3, K14, K24 - same manifolds/dp?
  44. Alternator bracket question!
  45. Starting problems
  46. Help with exhaust manifold. It was a gasket. Picture inside.
  47. How do I keep rain from affecting my cluster connections?
  48. AHU issues
  49. intermittent high idle on 1.6 na
  50. hill climbing overheating issue
