Author Topic: Oil pan leak  (Read 5178 times)
January 30, 2008, 03:32:36 pm
smoketrail
  • 10
Oil pan leak
« on: January 30, 2008, 03:32:36 pm »
couple of questions,first, ive got an oil leak from theoil pan,front   of the eng and towards the rear of the car with a new gasket, let the sealant set over night  ,and not over torqued ,and after each trip to work the bolts are loose 3 times also ,,,,,,,,,, breath,,,,,, can the inj timing be off a tooth  and still run ok ,just not want to start cold  ,20 F
89 jetta oil burner,71 bronco, 95 power stroke
Reply #1January 30, 2008, 03:41:59 pm
Oil pan leak
« Reply #1 on: January 30, 2008, 03:41:59 pm »
Timing needs to be spot on.
Are you using a torque wrench?
Reply #2January 30, 2008, 08:48:08 pm
Quantum TD
  • 1195
Oil pan leak
« Reply #2 on: January 30, 2008, 08:48:08 pm »
Gasket sealer? Did you use a normal gasket plus sealer, or just some silicone sealer? In theory, you don't need gasket+sealer. The gasket shoudl seal just fine, unless you have some ***ty cork pan gasket, in which case you should just throw it away and start all over with a composite gasket.
If you've just got a silicone gasket, REMOVE IT ASAP. When the silicone squeezes out, it will evenutally fall off into the pan and clog the oil pickup tube screen. This means low oil pressure, which then means blown engine.
If you've used a quality gasket, then there is no need for sealer.
As for timing: Burn's right. Timing should be spot on. If it's spot on and you're having trouble starting, then troubleshoot the glow system per Bentley. If that all checks out, then look to compression.
Good Luck.
Reply #3February 01, 2008, 07:49:19 am
BlackTieTD
  • 1512
Oil pan leak
« Reply #3 on: February 01, 2008, 07:49:19 am »
the injection pump in my car ran when it was 180 degrees out of time. if i were to guess i'd say you should be able to start it one tooth out. switch to light oil (a lot of us like rotella SB 0w40), make sure your starter/battery/cables are good, test glowplugs, etc.
Reply #4February 01, 2008, 05:04:22 pm
smoketrail
  • 10
Oil pan leak
« Reply #4 on: February 01, 2008, 05:04:22 pm »
glow plugs are new ,work as required ,tested with a test light the come on and off by the relay oil is 10 /40 royal purple
Reply #5February 02, 2008, 12:31:43 am
Baselyne
Oil pan leak
« Reply #5 on: February 02, 2008, 12:31:43 am »
Ya i had a little leak once in my pan... changed it and thought i was doing a good thing getting a new gasket...
Leaked more after i changed it, read on here that cork sucks and use composits only and so I put the old gasket on to get to the store and is hasnt leaked since!
I still have  the new gasket here in the box
f'in cork
Reply #6February 02, 2008, 04:52:12 pm
smoketrail
  • 10
oil pan
« Reply #6 on: February 02, 2008, 04:52:12 pm »
put a cork on it ,felpro  always had good luck with them, guess Ill get a GOOD gasket THX
Reply #7February 02, 2008, 11:22:14 pm
Baselyne
Oil pan leak
« Reply #7 on: February 02, 2008, 11:22:14 pm »
Yah i weas trying to install the felpro cork and It wouldnt stop leaking! I used the tightening spek with a torque wrench and everything...
Cleaned out the pan, the matting surface and all
I did'ntse any sealer tho so....
DOES EVERYONE USE GASKET SEALER WHEN INSTALLING NEW CORK?
Reply #8February 03, 2008, 01:40:20 am
Quantum TD
  • 1195
Oil pan leak
« Reply #8 on: February 03, 2008, 01:40:20 am »
Quote from: "Baselyne"
Perhaps they do, but I don't think too many folks fool with Felpro cork pan gaskets; they suck. Fiber gaskets nearly never leak, and you can upgrade to the rubber ones.
Reply #9February 03, 2008, 05:18:54 am
Baselyne
Oil pan leak
« Reply #9 on: February 03, 2008, 05:18:54 am »
Are any of them re-useable gaskets like the rubber V/C gasket that's re-useable from the 1.9's?
I have pulled few pans and seen gaskets that look like re-use jobbies...
Yes/No?
Reply #10February 03, 2008, 07:00:06 am
Oil pan leak
« Reply #10 on: February 03, 2008, 07:00:06 am »
It is on my 1.9. It's actually built into the windage tray.
Reply #11February 03, 2008, 03:17:20 pm
smoketrail
  • 10
oil leak
« Reply #11 on: February 03, 2008, 03:17:20 pm »
where to find a rubber ,or the best to seal it , cant find one on the internet or A/Z or ADV ???
