Author Topic: solar panel blowing fuse  (Read 5628 times)
January 31, 2008, 03:45:04 pm
cory
  • 20
« on: January 31, 2008, 03:45:04 pm »
I have a VW Solar Panel that I have been using for the past few years to keep my battery topped up in the cold winter months.
Recently is has started blowing the fuse whenever I plug it in.
Anyone have any input on why it may have started this new trick and/or what I can do to remedy the situation ?
Thanks
Cory
Reply #1January 31, 2008, 03:52:18 pm
« Reply #1 on: January 31, 2008, 03:52:18 pm »
contacts shorting out? is it all corroded? i would try other things in the cigarette plug to see if they blow the fuse a well.  if not then its your solar panel  :wink:
Reply #2January 31, 2008, 04:36:08 pm
cory
  • 20
« Reply #2 on: January 31, 2008, 04:36:08 pm »
The contacts are in great condition. My cell phone charger doesn't blow the fuse...but it is drawing current not feeding it. That seems like it would make a difference but I am not sure. My first thought was that the panel was faulty but I couldn't reason why it would fail out of the blue.
Reply #3January 31, 2008, 05:27:36 pm
MaxHedrm
  • 114
    • blog
« Reply #3 on: January 31, 2008, 05:27:36 pm »
Too sunny? That's really weird. I would imagine in order cause that it would have had to have shorted or something.
DRIVE: 2010 Golf TDI
DRIVE (less): 2001 TT Roadster
Reply #4January 31, 2008, 06:12:42 pm
« Reply #4 on: January 31, 2008, 06:12:42 pm »
does it blow the fuse right away?  what rating is the fuse?
Reply #5January 31, 2008, 09:10:55 pm
cory
  • 20
« Reply #5 on: January 31, 2008, 09:10:55 pm »
It does blow right away. It is a 15 amp fuse. The radio works fine, which is on the same circuit. Plug in the panel and...done.
Reply #6January 31, 2008, 10:03:39 pm
« Reply #6 on: January 31, 2008, 10:03:39 pm »
Probably a short in the cord or plug.
Reply #7February 01, 2008, 07:41:24 am
BlackTieTD
  • 1512
« Reply #7 on: February 01, 2008, 07:41:24 am »
ya a short in the solar panel electrics
Reply #8February 01, 2008, 11:52:45 am
Darkness_is_spreading
  • 288
« Reply #8 on: February 01, 2008, 11:52:45 am »
It will be one of two things.....   Check the continuity of the cables, then check the input to the board, there will be a zener diode or voltage regulator,  and in this case you may have an internal short.  Connect a scope to the ouput of the solar panel and see how clean the signal is, or measure the output with a volt meter, it should stay constant, then add a load (under rated load of solar panel) and see what the voltage level is at.
92 Jetta 1.6 T (Sleepin)
Reply #9February 01, 2008, 06:03:18 pm
bigblockchev
  • 271
« Reply #9 on: February 01, 2008, 06:03:18 pm »
I say short in the plug itself. Does the solar panel actually produce voltage, check the output with a volt meter. I'm not sure but I think the panel doesen't have much electronics associated with it maybe a diode maybe not. Just DC output and not much of that a few watts maybe 500ma to 1A output current in bright sun. Not much help in charging if it blows fuses. Cheers Dan
it's always something simple
87 Mercedes 190D 2.5 Turbo
2000 Jetta TDI
76 Onan  MDJF 15Kw genset
Reply #10February 01, 2008, 07:53:44 pm
silvertdi
  • 125
« Reply #10 on: February 01, 2008, 07:53:44 pm »
That's really wild.  I guarantee that solar panel is not putting out greater than 15 A.  Probably a few milliamps.  Is the wiring to the fuse box stock, or has it been spliced into?
Reply #11February 04, 2008, 08:44:01 am
cory
  • 20
Culprit Found
« Reply #11 on: February 04, 2008, 08:44:01 am »
I appreciate all of the insightful responses I got with this issue. Yesterday while I was waiting for my wife to fill up our growler at the brewery I thought I would see if the cigarette lighter would replicate the issue. So I popped in a new 15 Amp fuse and while I was grabbing the lighter from its typical home in the ashtray, I noticed a strange shine in the bottom of the cigarette plug.
I poked a pen down inside for further investigation and got some pretty sparks. I grabbed my flashlight for better light and could see that  a small key ring had fallen down into the hole and was seated nearly perfectly at the bottom of the plug. I tried again with the pen to get it out, more sparks and another blown fuse. After the fuse went I grabbed the ring and inspected it. It had 4 burn marks on it...funny that is the number of fuses I had gone through.
Anyway just wanted to let you all know, problem solved. Thanks again for all the input. It was an internal short, of a bizarre variety.
Cheers
Cory
