Author Topic: For MKII turbo diesels, T3, K14, K24 - same manifolds/dp?  (Read 6578 times)
January 23, 2008, 06:32:48 pm
Diesel Fumes
« on: January 23, 2008, 06:32:48 pm »
I have a T3, if I want to put a K24 on, does that require a different manifold or downpipe or is it direct bolt up?
Reply #1January 23, 2008, 07:01:09 pm
blkboostedtruck
  • 1535
« Reply #1 on: January 23, 2008, 07:01:09 pm »
Tyler (burn your money) i know has the answer for you!
Duane
'66 variant 1500S
'81 caddy 1.9 turbo diesel
'82 caddy gas 1.8 G60
 3 jettas '82' '04 '14TDI
Reply #2January 23, 2008, 07:15:12 pm
« Reply #2 on: January 23, 2008, 07:15:12 pm »
direct bolt on if they are both from a VW. The K14 is not a direct bolt on. It has a smaller air intake and boost pressure exit then the K24 and the T3 but it will bolt up to the manifold and the downpipe.
Reply #3January 23, 2008, 11:17:24 pm
Diesel Fumes
« Reply #3 on: January 23, 2008, 11:17:24 pm »
Quote from: "burn_your_money"
Perfect.
Now time to dump 650 bucks on a new K24 :(  :D
Reply #4January 24, 2008, 05:25:42 am
subsonic
  • 1836
« Reply #4 on: January 24, 2008, 05:25:42 am »
Do not pay that much.  You can get one for way cheaper.
Reply #5January 24, 2008, 06:50:29 am
BioDieselVW
  • 93
« Reply #5 on: January 24, 2008, 06:50:29 am »
Does anyone know the air intake diameter on a T3 as well as the boost pressure exit diameter? Im looking to do the swap also and want to get the correct size adaptors to plumb everything together :D
81 Caddy 1.6 TD
Callaway Intercooler
4in Exhaust Stack
Super Pump !
Reply #6January 24, 2008, 11:20:29 am
blkboostedtruck
  • 1535
« Reply #6 on: January 24, 2008, 11:20:29 am »
Quote from: "BioDieselVW"
Tyler should be abel to tell you the diameter? i bought his T3 and K14 from him! but he still has them! i have a K24 laying around that i can measure for you if you need?
thanks Duane
'66 variant 1500S
Reply #7January 24, 2008, 12:52:29 pm
« Reply #7 on: January 24, 2008, 12:52:29 pm »
Quote from: "blkboostedtruck"
Sure make me sound like an ass :P
I'll measure them after work or tomorrow morning
Reply #8January 24, 2008, 01:46:41 pm
BioDieselVW
  • 93
« Reply #8 on: January 24, 2008, 01:46:41 pm »
Thanks Tyler Your the man !
81 Caddy 1.6 TD
4in Exhaust Stack
Super Pump !
Reply #9January 24, 2008, 03:04:08 pm
Diesel Fumes
« Reply #9 on: January 24, 2008, 03:04:08 pm »
If someone has a new/remaned K24 to sell me for less than 625, then I am game for that.  PM me with details
Reply #10January 27, 2008, 11:50:24 am
BioDieselVW
  • 93
« Reply #10 on: January 27, 2008, 11:50:24 am »
Anyone know the sizes of the T3 ?
81 Caddy 1.6 TD
4in Exhaust Stack
Super Pump !
Reply #11January 27, 2008, 02:24:44 pm
subsonic
  • 1836
« Reply #11 on: January 27, 2008, 02:24:44 pm »
Are you looking for ID or OD?
Reply #12January 27, 2008, 07:47:25 pm
« Reply #12 on: January 27, 2008, 07:47:25 pm »
Quote from: "libbybapa"
The exit of the compressor is the same between the K14, K24 and T3.  It is only the compressor inlet and the oil return outlet that are different.  The pan fitting is the same.
Andrew
I stand corrected, right you are.
Does anyone want pictures?
Reply #13January 28, 2008, 06:41:44 am
BioDieselVW
  • 93
« Reply #13 on: January 28, 2008, 06:41:44 am »
Whats the inlets outside diameter T3 ? Thanks
81 Caddy 1.6 TD
4in Exhaust Stack
Super Pump !
Reply #14January 28, 2008, 08:06:23 am
« Reply #14 on: January 28, 2008, 08:06:23 am »
2 5/16"
