View full version: Troubleshooting
  1. how can i devise a reasonable way to test diesel injectors?
  2. engine running cold
  3. What exactly is broken?? :\
  4. all of my valves seem to be way too short. what gives?
  5. Glow plug issues.
  6. Switched to synthetic trany oil, now the tranny is loud
  7. Fuel at high rpm prob
  8. glow plug relay went car won't crank?
  9. Jetta parts for a golf?
  10. New Battery dead after sitting 2 weeks
  11. Hard to Start 1.6 EcoTD - Second Time Usually ???
  12. diesel running rough
  13. Blue smoke on startup and when cold
  14. Starting issues in humid/wet weather :\
  15. oil leak
  16. Clutch pedal movement
  17. Radiator Fans on Constantly
  18. TWO simple QUESTIONS about 91 jetta eco diesel??
  19. Canadian Tire semi-synthetic gear oil
  20. burning black smoke
  21. VW head rebuider in Toronto?
  22. Getting to bolts for the water pump
  23. lack of power TDI
  24. Should the exhuast mani gaskets etc be replaced at 226k??
  25. still not running the same day to day
  26. sensor in coolant tank broke, blowing all coolant out
  27. 1.6TD injection pump ill-running?
  28. Leaky master cylinder
  29. timing problems on 97 1.9 aaz
  30. Will a NON-TURBO rear muffler work for a 91 jetta eco TD??
  31. 89 n/a not getting fuel
  32. jetta 1.6td runs but won't start, injection pump??
  33. Took lid off pump, now no-start.
  34. Waterpump pulley bolts
  35. Dismantling Vacuumpump
  36. How can water fill up my rocker panel?
  37. IP dissection
  38. cannot get cylinder head off
  39. Pulling Turbo on 1.9 AAZ - Any Precautions?
  40. First time removing head
  41. Broken front mount
  42. exhaust nuts backing off???
  43. Dropplets of oil
  44. axle shaft seals
  45. Hand (parking?) brake Issue
  46. question on jetta switches ???
  47. break lights are stuck on GRRRRRRRRR!!!!!!!!
  48. Transmission surgery... need expert advice
  49. Golf GTD scheduled service
  50. where to find a 27mm hex head bolt
