Author Topic: Blue smoke on startup and when cold  (Read 6687 times)
August 07, 2005, 02:36:11 pm
toomanycars
  • 68
    • http://www.mathomfarm.com.au
« on: August 07, 2005, 02:36:11 pm »
What causes blue smoke when the engine is first running? Not just a little, but clouds of it. If I increase the revs to about 1800 the engine misses and farts blue amoke occasionally. Once at normal operating temperature the engine is fine. Isn't burning oil.
Regards, Peter.
1978 Golf diesel
1984 Nissan Patrol diesel
1986 Toyota Landcruiser 73 series 3B diesel
2006 Golf TDI 2.0 16v
Reply #1August 07, 2005, 02:52:38 pm
Maarten
  • 339
« Reply #1 on: August 07, 2005, 02:52:38 pm »
I think your timing is too Late so half combusted diesel enters the exhaust.. I've got the same prob, going to properly time it tomorrow :)
Audi A3 TDI '98
VW cabby '79
VW T3 1.9TD '91
Reply #2August 07, 2005, 05:06:23 pm
toomanycars
  • 68
Interesting.....
« Reply #2 on: August 07, 2005, 05:06:23 pm »
Yes, I have experienced blue smoke from overly advanced timing, but it usually occurs throughout running and is most evident when decelerating. I don't have a dial guage so I can't check timing but I'm fairly confident it's not out. I'm thinking perhaps dirty fuel or air in the system? I know that one of my tractors (that doesn't have a fuel guage) spits blue smoke just as it begins to run out of diesel, and if a fuel filter is blocked (there are 2) it does the same thing.
Regards, Peter.
1978 Golf diesel
Reply #3August 11, 2005, 02:14:22 am
  • 2932
blue smoke
« Reply #3 on: August 11, 2005, 02:14:22 am »
Is it whitish-blue smoke.
 I'm guessing timing too but I'm thinking retarded timing because it sounds like what happens when I don't pull the cold start lever in warm weather ... misses a little around 1800rpm, till it warms up.
 There was some blueish-white smoke coming from the Golf and it was starting hard, it got worse if I pushed the cold start lever back in shortly after it started. I advanced the timing and it starts much better now but does put out a little smoke and misses around 1800 at first. I'm going to try advancing it some more.
Reply #4August 11, 2005, 08:21:43 am
Maarten
  • 339
« Reply #4 on: August 11, 2005, 08:21:43 am »
Your right... got my english a little scrambled ;) It should be too late instead of too advanced.
Audi A3 TDI '98
VW cabby '79
VW T3 1.9TD '91
Reply #5August 15, 2005, 06:25:23 pm
fillmore
  • 60
    • http://fillmorenorthband.tripod.com
« Reply #5 on: August 15, 2005, 06:25:23 pm »
valve seals. had the same problem, my valve seals were shot, its a pretty easy fix if you know what your doing.
