Author Topic: Starting issues in humid/wet weather :\  (Read 5758 times)
June 15, 2005, 08:57:51 pm
VW Scully
  • 245
    • Not Quite Tom Riddle's Diary
« on: June 15, 2005, 08:57:51 pm »
Hey everyone;
My 81 Rabbit has been a bit grumpy starting lately in the really humid and wet weather. I usually have to pull the cold-start lever and today I even had to try 3 times to get her to fire up (we had TORRENTIAL rain last night!)
There is lots of battery power and it'll chug along for a while but not fire up.
Could this be glow plugs?? Moisture in fuel filter??? What!? :?:
Any help is appreciated.
btw, once the car is warmed up (i.e. I've driven 25 km to work or whatever), it starts right back up fine.
Thanks! :)
Tara aka VW Scully
**1981 Rabbit Diesel L, Biodiesel driven: 'the Bio-Bunny' **
Advocate for Young Adult Cancer Research & Support: I'm too Young for This!!
http://www.i2y.com
Reply #1June 16, 2005, 02:37:28 pm
chrissev
  • 694
Re: Starting issues in humid/wet weather :\
« Reply #1 on: June 16, 2005, 02:37:28 pm »
Quote from: "VW Scully"
Hey everyone;
Thanks! :)
my guess (and it's just a guess) would be it's something electrical.  The rabbits had this problem where water would leak onto the fuse box and then certain components wouldn't work after a heavy rain.  Usually the water leaked in either from a rust hole at the base of the windshield or along the radio antenae wire.
Reply #2June 16, 2005, 05:11:43 pm
VW Scully
  • 245
starting issues etc...........
« Reply #2 on: June 16, 2005, 05:11:43 pm »
Hey;
thanks :) I'm well aware of the common problems on Mk1s with water getting into the fuse panel area, but it just seems odd that it's only when it has to glow that it does this; and also in the really humid weather NOT just when it rains. My Dad and I are going to replace the glow plugs this weekend so we'll see that that does.
I notice sometimes after really heavy rain, there is some water on the floor of the passenger side but I've traced that to leaking out of the rain tray into the heater ducts so just have to fix the rain tray and make sure the rain drains out of the engine bay.
The latest issue I've discovered now is a coolant leak! Gee whiz, when it rains; it really does pour!  :shock:
I can't complain too much though; this car gets driven a LOT and really has been low maintenance this year; only big thing it needed was heater core, but now I have to figure out where this stupid coolant leak is coming from!  :roll:
Anyone up for a Mk1 Diesel GTG?? ;).
Tara aka VW Scully
http://www.i2y.com
Reply #3July 28, 2005, 08:22:49 pm
VW Scully
  • 245
Grumpy starting in wet
« Reply #3 on: July 28, 2005, 08:22:49 pm »
Well,
I replaced the Glow plugs and that didn't seem to change much; it still is rather grumpy about starting when it's REALLY humid or wet. It doesn't even have to have rained. You know how sticky it was the past couple of weeks. It wasn't even chilly at night, but the car would still be grumpy about starting in the morning (i.e. after sitting for several hours).
It *almost* feels like it's starved for fuel until I've tried about 4 times and then it will 'catch' and start up and then no problem for the rest of the day.
I will try to get that fuel filter changed next week and see if that makes a difference; it's over due and I have been running BioDiesel.
Any more ideas are appreciated!  :)
Tara aka VW Scully
http://www.i2y.com
Reply #4July 29, 2005, 07:13:44 am
Dennis Froelich
  • 258
« Reply #4 on: July 29, 2005, 07:13:44 am »
It sounds like maybe air in the fuel line to the pump. When you get it started, check for air bubbles in the fuel line to the pump if your fuel line is a clear one.
If you see air,  follow the fuel lines from front to rear and check for loose clamps or pin holes.
Hope this helps.
79 Golf GTD
96 Golf GTD(TDI)
02 Golf TDI 2 door
Reply #5August 12, 2005, 07:45:35 pm
VW Scully
  • 245
Fixed! :D
« Reply #5 on: August 12, 2005, 07:45:35 pm »
I replaced the glow plug fuse: FIXED! :D woohoo
(funny how sometimes it REALLY is just a little thing ;)).
Anyway, I still have to replace the water pump, fuel filter and replace the front shocks, so it's not ALL little things ;) but at least THIS problem is solved!
p.s. when are we going to have a Diesel GTG?? Summer is running away :(.
Tara aka VW Scully
http://www.i2y.com
Reply #6August 15, 2005, 05:22:49 am
BlackTieTD
  • 1512
« Reply #6 on: August 15, 2005, 05:22:49 am »
we better have one soon. i have my 82 TD back on the road now too so i'll be there in that (instead of that crummy GTI). lets get something organized!  :D
ps- i'm a pro at fuel filters and front suspension by now  :x  :lol:
