General Information
» Troubleshooting
View full version:
Troubleshooting
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
DASH NOISE!
AAZ turbo questions
Custom injector lines?
MPG setting on IP-1.6L diesel
3rd head gasket in 8 months?!
Cut rear strut bolt...good idea or bad news?
Major rattle at idle...adjust idle screw?
Snapped timing belt. Don't lie to me. Tell me it'll all be fine.
MKII heater no fan, 3 wire plug, 3 spade plug, HVAC controller power, etc.
1.6l crankshaft sprocket differences
AAZ injector line question
HELP ... removal of caliper brake hose
Something ain't going right ... re: bleeding MC and wheels
timing belt how to thread?
Resistance values of fuel level sender?
Bleeding brakes w/4 lines loose ? ?
HELP ! ! What's going on relative to my brakes rebuilding ? ?
A Few quick questions; (1.6td related)
IDI sitting about 10 years
Is this a problem ? ?
Wheel cylinder install -1981 rabbit pickup??
Dipstick Length Question
oil pressure gauge
water pump pullies
Ball joint mounting bolts size
Fuel line - Water Seperator to Fuel filter
AAZ vbelt swap issues
Brake parts advice follow-up
finding TDC with 190mm flywheel transplanted on my AAZ
Vanagon burning oil (has good compression)
You Guys With Hydraulic Heads...Is this Normal?
Bad tach signal?
Brake parts advice
Pump Timing
Speedo cable compatability
Help me identify this...
Clutch specifications
Could this be the ip going out?
another vanagon starting question
020 transmission... Play on output shaft/drive shaft
Bad ignition switch? No start 2-3 cranks in a row just now.
Is there a Heavy Duty P/S engine mount available for MK1 ??
NO glow plug light???
Acceleration Revving Issues...
m-TDI loads up when cold?????
98 jetta tdi stalling after warm starts (sometimes)
Broken engine mount thread bore
Dimmer lighting question
steering rack bypass pipe repair ?
Clacky diesel Clacks too loud?
