General Information
Troubleshooting
Dipstick Length Question
Topic: Dipstick Length Question (Read 4869 times)
May 06, 2010, 01:26:11 pm
Fuelfed
Newbie
May 06, 2010, 01:26:11 pm »
I have a stock 1983 Jetta Turbo Diesel. I'm not sure if the dipstick is OEM. When I change the oil and filter it requires 6.5 quarts to fill to the top mark. I do know the oil pan is stock.
My question is: What is the length of the metal dipstick from the top rubber stop down to the top mark? Pictures of an OEM dip stick would be great.
Thanks.
May 08, 2010, 12:47:12 pm
Baron VonZeppelin
Re: Dipstick Length Question
May 08, 2010, 12:47:12 pm »
If you use the large (NA) oil filter - 5 qts MAX.
4.8 qts is standard issue.
You have way too much oil in there !
I have a similar dilemma with a hybrid NA/TD i just changed the oil in for first time since purchase. 5 quarts puts nothing on the dipstick ! fuggenbich
I have a few other VWD cars with various engines that I'm going to pull dipsticks on and see if any gets a reading in this particular engine. Will measure the various dipsticks, too.
Glad I read your thread - to remind me to do this.
Will report back with findings. Maybe tonight.
May 08, 2010, 06:55:13 pm
Baron VonZeppelin
May 08, 2010, 06:55:13 pm »
I don't know which type your set-up will be.
My 82 NA has a short spout. You have to reach down in there to get to the dipstick. The dipstick has a looped metal pull rod on top.
The actual working length from top rubber stop to bottom is approx 7 and 3/4". I forgot you asked to measure to the top oil fill mark.
85 TD has a long spout. It comes up to about level with the throttle cable. Has an orange funnel cap on top of spout. Dipstick has a red plastic top with ears that snap down onto the orange funnel.
Actual working length is approx 19 and 1/2".
89 NA has long spout. About level with throttle cable. Yellow funnel cap on spout. Dipstick has yellow plastic top - no ears.
Actual working length is approx 20 and 1/4".
The NA/TD Hybrid has the long spout with red funnel cap. Had the red plastic top on dipstick with ears. But getting NO oil reading with 5 qts.
Put a yellow top dipstick from an 89 in there, and got a perfect oil level reading.
So now I know what I need for that one.
Junkyarding on Monday anyway.
Thanks for reminder !
May 09, 2010, 09:16:00 am
May 09, 2010, 09:16:00 am »
you just need the right length of dip stick for the tube you already have. what year is the engine? try and find another DS out of an engine of that year.
May 12, 2010, 03:56:48 pm
Fuelfed
Newbie
May 12, 2010, 03:56:48 pm »
Thanks for the replies.
The engine is a 1983 turbo diesel. In currently has a short DS with the curled metal handle with a red rubber stopper.
I'll take a picture tonight and measure it's length.
May 13, 2010, 01:45:58 pm
Fuelfed
Newbie
May 13, 2010, 01:45:58 pm »
Pix below are of the dipstick
It measures 20.25" from the red stopper to the metal tip.
Any help if this is correct for a 1983 Jetta Turbo Diesel?
Last Edit: May 13, 2010, 01:48:02 pm by Fuelfed
May 13, 2010, 02:13:02 pm
May 13, 2010, 02:13:02 pm »
same dip stick i have in my 84 TD engine. thats gonna be a hard one to find a replacement for. only one ive ever seen, is the one i own, every other one ive seen is different from the kind we have. i made my own dip stick tho, so the one i have is hanging on my wall as a spare.
May 14, 2010, 10:35:48 am
Fuelfed
Newbie
May 14, 2010, 10:35:48 am »
So the above pictures are the correct dipstick for a 1983, 1984 TD?
What's your oil capacity? With large oil filter I'm 6 quarts to full.
May 16, 2010, 07:04:10 am
May 16, 2010, 07:04:10 am »
never paid attention. in my 1.5TD, it takes right around 6 quarts. i would guess atleast.. i have an 84 oil pan, and dip stick on my 1.5
August 31, 2010, 07:56:07 am
motomike33y
August 31, 2010, 07:56:07 am »
so what would be the potential problems resulting if too much oil put in?
82 vanagon 1.6 waiting rebuild
81 jetta w/dasher 1.5 engine
91 jetta w/ 85 golf 1.6 NA- work in progress suzuki samurai hardtop that may someday be diesel
2012 golf tdi
General Information
Troubleshooting
