General Information
» Troubleshooting
View full version:
Troubleshooting
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
testing glow plugs
timing injection pump different pulley
Injection pump troubles.
Can you help me interpret my Spruce / VDO EGT?
HELP! Brakes not releasing...
Very slight miss at idle
Boost Controller Install ?
Temp Gauge showing overheat but engine not hot
New Turbo... Should I?
Vacuum pump woes.
Need to buy my 3rd speedo cable in a year, any suggestions??
Long term effects of ignoring oil in coolant?
Valve Cover Gasket Leak from German Auto Parts
clutch noise
coldstart lever position
more of a quiery really
tranny grinding going into second
Blue smoke
Feeler: Lotsa White unburnt Diesel
not your usual fuel filter change
help 1.6td trouble
AAZ driveable to junkyard without turbo?
Speedo Cable
1.9TD not starting.
A4 TDI (AFN) problem
poor idle behavior on a 1.6 NA.
Central locking was draining my battery
Rough idle/ no start
Can you guess where the oil leak is?
Wobbly...
Block heater / tank heater plug-in: what works for you?
Cold start cable adjustment
New t-belt, retimed pump, car catches but wont stay running
Drivers door wont lock
Valve seals
engine blow-by 1.6td
Timing belt mk3 1,9td
92 jetta no power
AAZ boost pipe querie
Suspected Gov problem but thinking otherwise
1.6 NA diesel pump leak
TDC crank question
Cylinder head golf mk3 1,9td
93 Jetta CV shaft
crack head, now what?
Timing Belt Tensioner with Spring - howto set it?
Instrument Cluster shuts off...
Good Thermostats?
Rebuilding The Oil Pump
Should I let my diesel warm up before driving?
