General Information
Troubleshooting
Boost Controller Install ?
Topic: Boost Controller Install ? (Read 4846 times)
February 28, 2009, 06:11:14 am
BioDieselVW
February 28, 2009, 06:11:14 am »
Im hooking up a manual boost controller to a K24. Now that I have split the steel line which side does the the in side of the line goes to the boost conroller. Im assuming its the cold side of the turbo, and then the exit side of the boost conroller is the wastegate side?
Thanks
81 Caddy 1.6 TD
Callaway Intercooler
4in Exhaust Stack
Super Pump !
February 28, 2009, 09:09:54 am
andy2
February 28, 2009, 09:09:54 am »
Thats corrrect.
February 28, 2009, 09:36:24 am
BioDieselVW
February 28, 2009, 09:36:24 am »
Thanks
81 Caddy 1.6 TD
4in Exhaust Stack
Super Pump !
February 28, 2009, 04:11:13 pm
turborabbit
User+
February 28, 2009, 04:11:13 pm »
Hey, BioDieselVW, just out of curiosty, do you burn "bio" in your caddy, if so, what form? I've heard of "wvo-ers" in south Florida running it without pre-heat, but the forum went down and I never heard about long-term effects. Just curious=warren
If "the more you know, then the more you know, you don't know, then I've got a lot to learn, since I'm forgetting what I thought I knew!!
01Dodge TD
81 Caddy TD
84 Winnebago/Renault TD
86Jetta84GolfCaddyCaddyCaddyCaddy
February 28, 2009, 04:18:55 pm
BioDieselVW
February 28, 2009, 04:18:55 pm »
I run B-100. Homebrew that I make myself. I have been running it for 4 yrs now w/ no problems. I just had to chage out some of the rubber lines.
81 Caddy 1.6 TD
4in Exhaust Stack
Super Pump !
February 28, 2009, 04:38:04 pm
turborabbit
User+
boost controller install
February 28, 2009, 04:38:04 pm »
Wow, that was fast-thanks. B-100 must be better for your caddy, but more effort. I've run 4/1 wvo/kerosene in a Ford pkup for several months with no known ill-effects. Do you recomend bio? Where would I start? I have all the shop space, barrels, totes, wvo and sunlight I would need. Appreciate the boost-warren
ps Is there glycerin left as a by-product? If so what do you do with it??
01Dodge TD
81 Caddy TD
March 01, 2009, 07:54:45 am
BioDieselVW
March 01, 2009, 07:54:45 am »
My processor is what they call an " appleseed processor ". If you google it you will get all sorts of info. There is a learning curve to making Bio but once you get it its very easy. Cost me about 60 cents a gallon to make. Glycerin is a by product. You can toss it or make soap out of it. or even use in compost as im told.
81 Caddy 1.6 TD
4in Exhaust Stack
Super Pump !
General Information
Troubleshooting
