Author Topic: AAZ boost pipe querie  (Read 3932 times)
February 08, 2009, 04:10:00 pm
LoneWolf
« on: February 08, 2009, 04:10:00 pm »
Hi all,
  ive got an AAZ lump with standard turbo in my mk2 gtd, but im having pipework troubles still. the outlet of the turbo is 1.5", whereas my pipework to the inter cooler is 2", can someone please post a couple of photos of how theyve solved this conundrum?
 also what do you guys use to hold your pipes on with? ive tried jubilee clips, but the pipes STILL keep blowing off   :?
 cheers,
              Matt
Reply #1February 08, 2009, 04:40:15 pm
truckinwagen
  • 1895
« Reply #1 on: February 08, 2009, 04:40:15 pm »
you can buy transition joiners for pretty cheap(try siliconeintakes.com)
and I use t-bolt clamps, the ones with nuts on them so you can get a wrench on them and get them really tight.
-Owen
83 Opel Kadett Diesel
Reply #2February 09, 2009, 12:32:12 am
LoneWolf
« Reply #2 on: February 09, 2009, 12:32:12 am »
Quote from: "libbybapa"
I always bead the pipe ends and use the above mentioned clamps.  That's good for at least 30 psi.
Check eBay for couplers and reducers.
Andrew
 how do you do this?
Reply #3February 09, 2009, 08:09:14 am
« Reply #3 on: February 09, 2009, 08:09:14 am »
the pipe beading should be put in the FAQ  :)
