Author Topic: Wobbly...  (Read 4632 times)
February 15, 2009, 02:07:47 pm
Jettage1
  • 202
    Past VWs: 80 Scirocco S, 90 GTI, 00 Passat GLX
Wobbly...
« on: February 15, 2009, 02:07:47 pm »
...balancer.  (Maybe owner, too...)
How much runout (wobble) is normal in a two-pulley harmonic balancer?  While looking for unrelated trouble with the engine running, I happened to notice some wobble in the balancer pulley.  (1.6 TD with A/C)
Thanks...
Steve
92 Jetta EcoDiesel
     pumped by Giles...powered by Frybrid...functional by dumb luck
Reply #1February 15, 2009, 04:06:19 pm
Re: Wobbly...
« Reply #1 on: February 15, 2009, 04:06:19 pm »
Quote from: "Jettage1"
Thanks...
there's a small chance that you have the dreaded crank sprocket issue more common with the 1.9 AAZ engines.  it is much more common with the serpentine belt pulley system.  if you can take a short video clip of the wobbling, that will also help diagnose the problem.
Reply #2February 15, 2009, 04:20:07 pm
Jettage1
  • 202
Wobbly...
« Reply #2 on: February 15, 2009, 04:20:07 pm »
Hmmmmm.  I'll see if I can do some sort of video clip.  Haven't tried to post one before.  Guess I need to get up to speed with this stuff.
Steve
92 Jetta EcoDiesel
Reply #3February 15, 2009, 10:22:14 pm
Wobbly...
« Reply #3 on: February 15, 2009, 10:22:14 pm »
maybe you could view some video's of the 1.9AAZ pulley wobble to get an idea of what to look for?  i know there has to be at least one floating around on here... i sure hope thats not the case though.  if its not too bad at this point, possibly getting the crank end machined flat, and a new pulley with a new crank bolt (properly torqued) would solve the problem.
Reply #4February 16, 2009, 03:26:32 am
dillenger1
  • 777
Wobbly...
« Reply #4 on: February 16, 2009, 03:26:32 am »
1.6td in toyota pickup
10mm head ,t3 intercooled.
Reply #5February 16, 2009, 07:39:34 am
Choppercat
  • 42
Wobbly...
« Reply #5 on: February 16, 2009, 07:39:34 am »
Here's mine:
http://www.youtube.com/watch?v=X7AKSWd4UjU
Not quite as bad but I've driven it like that for over 200K Kms sor far.
Not to highjack this tread but would defenetly like to know how much wobble is too much?
DIESEL SMOKE IS ADDICTIVE!!!
'93 AAZ Golf
'99 Jeep TJ
Project: '51 Willy's CJ-3A AAZ
