View full version: Troubleshooting
  1. IP rotor pump and head gasket leaks ?
  2. idle problem, daf45 cummins160
  3. Tapping, What can it be???
  4. brake bleeder screw
  5. 93 golf heater core replacement
  6. rad fan resistor (with A/C)
  7. My block 0.0015" over last oversize - still usable?
  8. little end size/clearance
  9. Wobble's Gone, But Engine's Unhappy
  10. Engine Electronics Fuse Blowing...
  11. motor mounts
  12. Minimum Cylinder Compression numbers needed ???
  13. Need help with cruise control connections
  14. Found this in my oil pan - what is it?
  15. newb needs help in seattle!!
  16. Crankshaft pulley wobble, 94 Jetta TD
  17. Need VW 210 gauge directions
  18. throttle lever position
  19. Instrument cluster interchangability?
  20. ip primed, stop solenoid clicks, still no fuel to injectors?
  21. Help!! Cant get the Crankshaft pulley off!!!! 1.6D N/A
  22. noisy fuel pump?
  23. Tether strap for achild's car seat? 91 Golf 2 door
  24. Compression testers
  25. Help with Engine Code
  26. Hose connections
  27. Getting Water Pump Off
  28. Turbo not as audible??
  29. really dumb question about front license plates
  30. Which is TDC?
  31. 93 golf IDI bosch fuel pump timing spec
  32. broke a timing belt......... :(
  33. Need some part numbers---
  34. inj pump runaway
  35. alternator parts
  36. And another AAZ engine bites the dust
  37. 1990 jetta 1.6l has oil in coolant
  38. Plugged a/c condensate drain - '92 Jetta
  39. possible solution for my overheating issue? please read..
  40. Steering Rack internal plumbing--94 Mk3 Jetta TD
  41. 1.6TD hard start new glowplugs HELP
  42. Running hot low power Please give me some input
  43. What are these switches on my diesel injection pump?
  44. Turbo or Non-turbo injector question
  45. Where to tap into the cooling system for a gauge??
  46. oil pressure sending units and wiring
  47. Heat shield help
  48. Running hot again... still
  49. High idle after turning up fuel [Did search, but no answer]
  50. More than timing issues!!!
