Author Topic: And another AAZ engine bites the dust  (Read 15765 times)
June 26, 2007, 01:49:59 pm
AadmanZ
« on: June 26, 2007, 01:49:59 pm »
Hallo all, new here, have a Caddy with an AAZ engine. great car, great engine so far..
And yes, I too have a pulley that came undone.. Being a total VW noob I had no idea that I should've checked this..
What to do now? (very basic skills, decent tools, but no VW/car specific)
    A. check crank end, put on new pulley bolt, time everything correctly and try to start it, what's broken is already broken.
    B. Take the head off, check valves and pistons for damage, (if needed, get a new head) check crank end for damage, new pulley, new bolt, new belt, get an expert in to time everything and run it.
    C. Screw it, engine is done for, valves are surely bent/broken, crank end is cracked, buy a new engine and swap it.
Will check crank end later this week anyway, have not had time to do that just yet.
My main question is, how to assess the extent of the damage? and minimize the cost of the operation?
Suggestions are appreciated..
Reply #1June 26, 2007, 02:22:48 pm
« Reply #1 on: June 26, 2007, 02:22:48 pm »
where did it break? if it broke while idling, then you probably don't have severe damage.  if it broke while on the highway, the motor will have extensive damage.
Reply #2June 26, 2007, 04:14:16 pm
« Reply #2 on: June 26, 2007, 04:14:16 pm »
Pop the valve cover off and have a look for anything out of the ordinary, like metal shavings, messed up lifters etc
Reply #3June 26, 2007, 11:50:48 pm
AadmanZ
« Reply #3 on: June 26, 2007, 11:50:48 pm »
Quote from: jtanguay
It broke while starting. I heard a slight rattle while driving, didn't trust it, parked the car, started it up two days later, it coughed twice and then just turned over on the starter motor.
Reply #4June 26, 2007, 11:52:12 pm
AadmanZ
« Reply #4 on: June 26, 2007, 11:52:12 pm »
Quote from: burn_your_money
No metal shavings, nothing out of the ordinary as far as I can see. Can't see any lifters (must be hydraulic  then?)
Reply #5June 27, 2007, 04:14:45 am
« Reply #5 on: June 27, 2007, 04:14:45 am »
Quote from: "AadmanZ"
Quote from: "jtanguay"
you might be lucky then...  maybe just fix the crank pulley, and re-time it?
Reply #6June 27, 2007, 06:17:44 am
Doug
« Reply #6 on: June 27, 2007, 06:17:44 am »
You can count on at least several bent valves.
Reply #7June 27, 2007, 06:19:47 am
AadmanZ
« Reply #7 on: June 27, 2007, 06:19:47 am »
Quote from: Doug
Figured as much, but do I need to take the head off to check this?
Reply #8June 27, 2007, 10:03:15 am
Doug
« Reply #8 on: June 27, 2007, 10:03:15 am »
I think that you are getting a bit ahead of yourself. Assuming that no valves are bent (I wish that for your sake but will amost guarantee that there are some that will be bent) and you are going to set the crankshaft, camshaft and pump in correct relation to each other to get the timing belt in place, then doing a compression check afterwards would tell you if you have leaking valves (hence damaged).
If you have the time why not pull the head, repair valves, replace head gasket (a normal maintenance item) then spend the time to get the crank aligned to the camshaft and pump with a new timing belt and crank sprocket? It would be a better use of your efforts.
Reply #9June 27, 2007, 10:15:49 am
AadmanZ
« Reply #9 on: June 27, 2007, 10:15:49 am »
Quote from: Doug
I guess you are right, I will check the crank to see if there is any damage there, if not, just take the head off for inspection.
Reply #10June 27, 2007, 02:10:59 pm
« Reply #10 on: June 27, 2007, 02:10:59 pm »
burn your money was selling a motor that jumped time probably because of crank pulley.  he re-timed it and it worked.  i think he probably used a new crank bolt though...
who knows, it may be your lucky day!!!   :)
Reply #11June 27, 2007, 02:24:25 pm
« Reply #11 on: June 27, 2007, 02:24:25 pm »
Sure didn't. The crank felt perfectly solid. I'm parting that engine out instead though. Once I retimed it it ran just fine. If you suspect any problems with the crank though have it completely inspected
Reply #12June 28, 2007, 12:28:34 am
AadmanZ
« Reply #12 on: June 28, 2007, 12:28:34 am »
Will check this evening.. Anyone have a Timing how to? Will have to order a Bentley manual, but haven't gotten round to it.
Reply #13June 28, 2007, 06:58:38 am
Doug
« Reply #13 on: June 28, 2007, 06:58:38 am »
Reply #14June 28, 2007, 11:10:11 am
Mark(The Miser)UK
  • 1557
« Reply #14 on: June 28, 2007, 11:10:11 am »
Are you sure that anything is damaged internally? Would you be able to drive with the symptoms of only a 'slight rattle' if timing was off and valves hitting or even stuck open due to being bent?
I feel very optimistic... makes a change  :roll:
Sure it won't start now but that's another issue
Mark-The-Miser-UK
