Author Topic: newb needs help in seattle!!  (Read 6900 times)
August 23, 2007, 02:03:53 pm
2mAn
« on: August 23, 2007, 02:03:53 pm »
i finished rebuilding my motor (1.6td) , but i am very inexperienced with timing the pump. a friend helped out and the car will start, but it doesnt like to idle. plus on top of that there is a lot of smoke so i am freaking out. i have tried to have my mechanic help, but getting him to my house is like trying to get a pizza delivery guy pick up some brews for you, it aint gonna happen....
i have a bentley and i just bought the tools to time the motor. i will be trying to again this weekend, but i got beers ( or whatever ) for whoever helps me.... PLEASE!!  :oops:
Reply #1August 23, 2007, 02:06:53 pm
« Reply #1 on: August 23, 2007, 02:06:53 pm »
I would be there in a sec if I was closer..
Timing mark is on the flywheel, look through the hole on top of the bellhousing. insert the dial indicator in pump and follow the instructions in your bently.
Reply #2August 23, 2007, 02:19:59 pm
2mAn
« Reply #2 on: August 23, 2007, 02:19:59 pm »
Quote from: "zukgod1"
the marks on the camshaft & flywheel line up. its just the pump timing i am having trouble with... like i said though i will be trying it again, but id like an expert (or at least something close)
Reply #3August 23, 2007, 06:22:44 pm
« Reply #3 on: August 23, 2007, 06:22:44 pm »
The procedure is covered in the Bentley and is explained in pretty good detail... here's another link, although you have to ignore the "preset the gauge to  1mm" in the first description... the second description is a scan from the Bentley:
http://www.vwdieselparts.com/injtim.htm
Best if you read the procedure and then post with specific questions.... any day now I'm going to do a pictoral HOW-TO since it seems scary but it isnt.
Reply #4August 23, 2007, 08:37:14 pm
2mAn
« Reply #4 on: August 23, 2007, 08:37:14 pm »
ok maybe its just me. ill do it with the help of the site. sunday will be funday since thats my only day off. til then, thanks
-simon
Reply #5August 23, 2007, 09:36:43 pm
« Reply #5 on: August 23, 2007, 09:36:43 pm »
Quote from: "2manVR6"
-simon
Holler if you get stuck... the VW Diesel interweb never sleeps !!
Reply #6August 24, 2007, 03:59:42 pm
2mAn
« Reply #6 on: August 24, 2007, 03:59:42 pm »
Quote from: "Vincent Waldon"
... here's another link, although you have to ignore the "preset the gauge to  1mm" in the first description....
 do i leave the gauge alone when it stops moving or what?
Reply #7August 24, 2007, 04:08:43 pm
« Reply #7 on: August 24, 2007, 04:08:43 pm »
When it stops moving you turn the gauge face to reset it back to 0. Don't actually move the gauge, just the scale.
It just makes it easier to see how much advance you have.
Reply #8August 25, 2007, 12:24:49 am
2mAn
« Reply #8 on: August 25, 2007, 12:24:49 am »
cool, and what should i set it to. IIRC my mechanic set it to .90?
Reply #9August 25, 2007, 09:32:26 am
« Reply #9 on: August 25, 2007, 09:32:26 am »
I usually set my cars at 1.00 or 1.05
Reply #10September 03, 2007, 08:54:40 pm
2mAn
« Reply #10 on: September 03, 2007, 08:54:40 pm »
UPDATE:
finally spent enough time on it to get it right. it was very very very out of spec, but after about 3 attempts (if that) we had it set perfectly on 1.00 and she fired right up. i even took her around the block just to make sure there was no issues. if the alignment wasnt so off i would still be driving her right now.
thanks for everyones help, there was no way i could have done it without ya'll :D  :D  :D  :D  :D  :D
it should be my daily again before the week is over, i just have to take it to the alignment shop and get the final approval and once over from chris at fine tuning, then im set. thanks again
-simon
