Author Topic: Getting Water Pump Off  (Read 5162 times)
August 24, 2007, 11:35:18 am
Trimster
  • 74
« on: August 24, 2007, 11:35:18 am »
I need to R&R the water pump on my '83 CAddy diesel.  It has AC as well. Anyway of getting that baby off without pulling the fuel pump, AC and alternator?  Oh please say 'yep'.
bob
Bob
'83 Caddy, 1.6 NA Diesel, 5 speed, AC
2- motorcycles, 36' 5th wheel, sailboat, RC airplanes... to many interests, not enough time.
Reply #1August 24, 2007, 11:57:13 am
MikkiJayne
  • 235
« Reply #1 on: August 24, 2007, 11:57:13 am »
Nice try but no way sorry!
The alternator and A/C have to come off, as their mounting bracket is bolted on to the water pump. The fuel pump can stay on though.
Good luck!
Mikki x
Reply #2August 24, 2007, 12:55:34 pm
Trimster
  • 74
« Reply #2 on: August 24, 2007, 12:55:34 pm »
thanks... Here I go.
bob
Bob
Reply #3August 24, 2007, 03:23:00 pm
« Reply #3 on: August 24, 2007, 03:23:00 pm »
Or you can do it the other way (which I never recommend but I've never dealt with AC)
You need to remove the timing belt though and you can take the pump off and leave the housing on. This method can be a real PITA though because the 10mm bolts that hold the pump to the housing tend to break off
Reply #4August 24, 2007, 03:53:43 pm
BlackTieTD
  • 1512
« Reply #4 on: August 24, 2007, 03:53:43 pm »
hey bob. i took some pictures when i did a waterpump last time. not on an AC car but similar idea. about 1/2 way down: http://www.vwdiesel.net/phpBB/viewtopic.php?t=1877&postdays=0&postorder=asc&start=30
Reply #5August 24, 2007, 08:41:03 pm
Trimster
  • 74
« Reply #5 on: August 24, 2007, 08:41:03 pm »
... 4 hrs. and a bit of flesh left behind.. I am still fighting the AC bracket mounting bolts that go through the water pump housing.  I think they used some kind of sealant on the threads. It's a fight for every turn.  One is out, the other is staring at me.. saying...' hay buddy, just try and get me out. I dare you.'  Just trying to figure an approach with a breaker bar.
I hate this part of the game.
bob
Bob
Reply #6August 25, 2007, 02:37:54 am
Mark(The Miser)UK
  • 1557
« Reply #6 on: August 25, 2007, 02:37:54 am »
Quote from: "Trimster"
bob
Try squirting it with something wet and slippery and tightening it back in and then back out....
Mark-The-Miser-UK
Reply #7August 25, 2007, 10:08:24 am
« Reply #7 on: August 25, 2007, 10:08:24 am »
if you're replacing the whole pump, unbolt the water pump from the housing and put some anti seize on the bolts.
good luck
Reply #8August 25, 2007, 12:33:29 pm
smutts
  • 720
    ClackClackClackClackClack
« Reply #8 on: August 25, 2007, 12:33:29 pm »
One of the 13mms hides behind the injection pump and is a complete arse to deal with. Do yourself a favour and get a set of "bent", "obstruction", "standard Citroen Peugeot", spanners and it becomes doable. Good luck.
Try changing the thermostat before bolting the water pump onto the car, this saves on rolling the car onto its roof to stop the wretched thing falling out,  or use superglue! :D
