Author Topic: injector seat fix??  (Read 4846 times)
April 30, 2005, 06:47:13 pm
okiediesel
  • 4
injector seat fix??
« on: April 30, 2005, 06:47:13 pm »
The seat under the heat shield in no. 1 has got a notch burnt in it. I have an 84 1.6td from a Jetta planted in a caddy. Can the seat for the heat shield be repaired in-car (dremel, cutter bit,...)? I'm stuck right now with the injectors out. :(
Reply #1January 10, 2006, 04:55:44 pm
okiediesel
  • 4
injector seat fix??
« Reply #1 on: January 10, 2006, 04:55:44 pm »
Fixed my head. Used an old heat shield and a dowel to make a cutter. Screwed the heat shield to the end of the dowel w/ a dime sized piece of 80 grit belt sander paper covering the bottom of the rig. Went through about a dozen dime papers but it worked. The heat shield kept the shape about right, and the paper did the work. Sealed it right up.
Reply #2January 10, 2006, 05:05:46 pm
Justin
  • 455
injector seat fix??
« Reply #2 on: January 10, 2006, 05:05:46 pm »
Good to hear that you fixed it, I have seen a lot of threads in the past wondering if there is a fix for that problem, now if it happens to me I will know what to do
www.archeryprostaffmi.com
Reply #3January 12, 2006, 05:05:35 am
chrissev
  • 694
injector seat fix??
« Reply #3 on: January 12, 2006, 05:05:35 am »
Quote from: "okiediesel"
how did you get the metal filings and pieces of sand out?  or did you just start it and let them get blown out the exhaust?
Reply #4January 15, 2006, 02:00:01 pm
hillfolk'r
  • 1532
injector seat fix??
« Reply #4 on: January 15, 2006, 02:00:01 pm »
how did you get the metal filings and pieces of sand out?  or did you just start it and let them get blown out the exhaust?[/quote] heh,don worry bout it heh
Throttle cables ftw
