Author Topic: Bad injector symptoms?  (Read 5522 times)
January 22, 2006, 07:13:44 pm
Jeff@TheQuadShop
  • 42
« on: January 22, 2006, 07:13:44 pm »
What are the symptoms of a bad injector? I just installed a new 1.9 longblock and now the motor has a shimmey too it. I notice it mostly in 5th gear at around 2000 rpms.  :x
Reply #1January 23, 2006, 07:19:57 pm
Master ACiD
  • 328
« Reply #1 on: January 23, 2006, 07:19:57 pm »
you would notice it in every gear, not just 5th. you probably have a tyre issue.
Reply #2January 23, 2006, 08:13:08 pm
Jeff@TheQuadShop
  • 42
« Reply #2 on: January 23, 2006, 08:13:08 pm »
I know its not the tires as it didn't do it before I installed the new longblock. It does it in other gears just not as bad as 5th. The motor is also shaking around some at idle.
Reply #3January 26, 2006, 05:35:08 am
Jeff@TheQuadShop
  • 42
« Reply #3 on: January 26, 2006, 05:35:08 am »
It was the injector, one of the needle valves was stuck closed. When I freeded it up, the very sharp part of the tip broke off(so small its hard to see the piece that broke off). Its running good but I'm assuming it has a bad spray pattern now. Does that sound about right?
Reply #4January 30, 2006, 03:54:08 pm
Redlined
  • 18
« Reply #4 on: January 30, 2006, 03:54:08 pm »
Did you remove the axles?
Natures D student
Reply #5January 30, 2006, 04:57:47 pm
Jeff@TheQuadShop
  • 42
« Reply #5 on: January 30, 2006, 04:57:47 pm »
Quote from: "Redlined"
What does that have todo with the question I asked?
Reply #6January 30, 2006, 05:44:29 pm
Redlined
  • 18
« Reply #6 on: January 30, 2006, 05:44:29 pm »
Quote from: "Jeff@TheQuadShop"
I read the tire issue before penetrating you're question.
I would say a faulty motor mount...even though it was fine before. Forgot to tighten something up?
Natures D student
Reply #7January 30, 2006, 06:06:06 pm
Jeff@TheQuadShop
  • 42
« Reply #7 on: January 30, 2006, 06:06:06 pm »
Read the 4th post  :wink:
Reply #8January 30, 2006, 06:07:37 pm
Redlined
  • 18
« Reply #8 on: January 30, 2006, 06:07:37 pm »
I have selective reading syndrome  8)
Natures D student
Reply #9January 30, 2006, 06:11:10 pm
Jeff@TheQuadShop
  • 42
« Reply #9 on: January 30, 2006, 06:11:10 pm »
LOL
