Author Topic: smoke smoke smoke  (Read 4843 times)
January 15, 2006, 10:12:25 am
Malacaco
  • 51
smoke smoke smoke
« on: January 15, 2006, 10:12:25 am »
ok guys, here's my prob. Switched the na 16d engine to a 1.6 td in my MKI golf. I started solving all the probs in it. The pump had a leakage thats already solved; sticky wastegate solved too and some minor problems. The only problem i cant solve is the smoke. Too much smoke. The injectors are brand new, and are Bosch. What can you guys tell me??
1983 VW Golf MKI with swapped engine (1.6D to 1.6TD)
http://batracer.com/-1FrontPage.htm?1E.
--->check it out
Reply #1January 15, 2006, 02:22:37 pm
cipo28
  • 36
Re: smoke smoke smoke
« Reply #1 on: January 15, 2006, 02:22:37 pm »
Quote from: "Malacaco"
...this could be the inj. pump or more likely the timing is wrong!!!
'94 VW Golf GL 1.9TD/AAZ
Reply #2January 16, 2006, 02:03:08 am
  • 2932
smoke
« Reply #2 on: January 16, 2006, 02:03:08 am »
More info ... black smoke? White smoke?
 Low RPMs? High RPMs? Midrange?
Reply #3January 20, 2006, 11:22:28 am
Malacaco
  • 51
smoke smoke smoke
« Reply #3 on: January 20, 2006, 11:22:28 am »
Black smoke at all rpm range when accelerating, but i talked to an expert today and he said the timing was advanced, not manually (when you move the pump) but in the belt, im going to retard a tooth and then im going to see what happens. I knew it was strange the engine heating to much when idling. Thnx for the replies anyway m8s :)
--->check it out
