Author Topic: Fuel tank problems  (Read 4117 times)
February 06, 2006, 07:57:58 am
zyewdall
  • 393
Fuel tank problems
« on: February 06, 2006, 07:57:58 am »
I've got a question on the fuel tank.  I'm trying to hook up the new diesel engine to the old gas tank in the '91 GTI, and I can't get it to stop sucking air into the fuel line.  The tank is half full of biodiesel, so that shouldn't be the problem.  I took out the fuel-pump/filter/accumulator under the back of the car and plumbed the supply and return lines straight through.  In the engine compartment I have a small electric fuel pump, then of course the one built into the IP.  The problem is that it is drawing air into the supply line (seems to deliever about half air and half fuel), which eventually airlocks the engine.  If I dip the hose under the back of the car into a jug of fuel instead of the line coming down from the fuel tank, it works fine, so it must be somewhere right after the fuel tank, or in the fuel tank somehow.
For now, I've got a 2 gallon jug of fuel in the engine compartment, but that's certainly not a long term solution.  Is there some design feature of these fuel tanks that I'm missing, or should I just drop the fuel tank and see if something got screwed up on the fuel line coming out?  There is a third line coming up, which I think was part of the evaporative emissions system.  Do I need to cap that off maybe?
'89 Subaru 4x4 touring wagon
1976 Ford Sasquatch pickup
Reply #1February 09, 2006, 04:06:47 pm
zyewdall
  • 393
Fuel tank problems
« Reply #1 on: February 09, 2006, 04:06:47 pm »
Ahah.   Guess what was wrong....  I had swapped the supply and return lines.  Guess you can't suck much fuel out of the return line.  I'm suprised I was able to get any at all.    :oops:  :oops:
