Author Topic: Is Using a MKII tophat with MKIII spring Dangerous??  (Read 3412 times)
October 18, 2009, 08:06:13 pm
mtnbob
  • 738
« on: October 18, 2009, 08:06:13 pm »
Just switched out my struts and springs. I used springs from a VR6 MKIII. The tophats on my MKII didn't quite fit the springs from the MKIII, but I used them anyway. I was wondering if anyone knows if it is dangerous to do so. BTW I now have an offroad-looking Golf The springs lifted it up about 3-4" in the front and back. ;D
Thanks
Robert
« Last Edit: October 19, 2009, 02:32:39 am by mtnbob »
96 Subaru Outback Wagon
Reply #1October 19, 2009, 02:27:22 pm
mtnbob
  • 738
Re: Is Using a MKII tophat with MKIII spring Dangerous??
« Reply #1 on: October 19, 2009, 02:27:22 pm »
Still wondering :(
Reply #2October 19, 2009, 11:12:10 pm
neimis
  • 75
« Reply #2 on: October 19, 2009, 11:12:10 pm »
A few years ago I used some aftermarket "top hats" with my Passat, they didn't have quite the slant that the original OEM ones had. The spring puts a sideways pressure on the top hat, the hole for the strut got worn into an oval, which caused looseness and clunking. When I replaced them with OEM ones that fit properly, it was obvious that they fit much better.
Short answer, you could probably get away with it, but it might cause accelerated wear of other components...  (my best guess, anyway)
'92 Passat TD
'01 Golf TDI
'15 Golf TDI
