Author Topic: 1990 JX engine. Oil light flashes when engine warms up  (Read 6995 times)
October 19, 2009, 03:50:49 pm
1990panelvan
« on: October 19, 2009, 03:50:49 pm »
Hey everyone, ive just put my 1600td JX engine back together. Replaced the head, Re-ringed the pistons and put new shells in. also put in brand new oil pump.
She run really well...But
After about 5 mins of driving the oil light starts to flash.
What could this be?
Hope someone can help
Tony
Reply #1October 19, 2009, 06:16:54 pm
Re: 1990 JX engine. Oil light flashes when engine warms up
« Reply #1 on: October 19, 2009, 06:16:54 pm »
It's likely flashing because your oil pressure is quite low when cold and gets even lower as the oil heats up and thins out.... I'd recommend you not drive it with the light on until you get an oil pressure gauge in place to find out what's going on.
Additional troubleshooting info here:
http://vincewaldon.com/index.php?option=com_content&task=view&id=40&Itemid=28
The usual cause of low oil pressure is worn bearings... mains, rods, and especially intermediate shaft.
Reply #2October 19, 2009, 08:30:54 pm
Rabbit TD
  • 840
« Reply #2 on: October 19, 2009, 08:30:54 pm »
Just out of curiosity what kind of oil are you using and did you check the clearance on your bearings with plastigauge
Reply #3October 20, 2009, 12:03:37 pm
1990panelvan
« Reply #3 on: October 20, 2009, 12:03:37 pm »
Using Fuchs 15-40.
Got standard shells from main dealer, didn't use the plastigauge to check.
Reply #4October 20, 2009, 12:11:23 pm
Powered by Spearco
  • 1203
« Reply #4 on: October 20, 2009, 12:11:23 pm »
Just a thought here, but does your vehicle have the dynamic oil pressure system? It might be that the relay for it is intermitantly fritzing out  ::).
'78 Rabbit..Gas Weekend Racer
'13 Golf R:. Tuned
'98 Puch G320
Reply #5October 20, 2009, 12:12:59 pm
1990panelvan
« Reply #5 on: October 20, 2009, 12:12:59 pm »
I do believe that it does. hmmmmmm interesting
Reply #6October 20, 2009, 09:42:53 pm
« Reply #6 on: October 20, 2009, 09:42:53 pm »
As per the troubleshooting link previously mentioned. ;)
Reply #7October 23, 2009, 04:13:34 am
1990panelvan
« Reply #7 on: October 23, 2009, 04:13:34 am »
Ok all the sensors are in order, definitely getting oil pressure to the sensor in the oil filter housing.
Got the van warm untill the flashing oil light comes on. Took the rocker cover off and fired it up to see whats going on there.
oil is pissing out the side of one of the camshaft bearings. should it be doing this?
Reply #8October 23, 2009, 06:40:05 am
« Reply #8 on: October 23, 2009, 06:40:05 am »
Depends on what you mean by "pissing".  ;)  Oil should be leaking out the sides of the cam bearings... that's how they are lubricated.
What oil pressures did you measure at the head and the filter with the engine hot?  Do you just have a flashing light or a buzzer as well?  Over 2000 RPM or under?
Reply #9October 23, 2009, 07:25:30 am
1990panelvan
« Reply #9 on: October 23, 2009, 07:25:30 am »
Haha by pissing i mean like sprinkling out...hmm like a catherine wheel suppose, this is only on one of them. Should they all do this?
Its just a flashing light. I have no gauge as yet. I did have a autogauge oil pressure gauge attached to the head but I could get hardly anything out of it cold or hot. I wasnt sure if it was working correctly.
Reply #10October 25, 2009, 09:11:05 pm
« Reply #10 on: October 25, 2009, 09:11:05 pm »
The lights telling you you have no oil pressure, and so is your gauge.  Highly recommend you don't drive it until you get it sorted. ;)
