Author Topic: Fast idle  (Read 4751 times)
April 03, 2008, 09:18:32 am
Fast idle
« on: April 03, 2008, 09:18:32 am »
When I first start my engine, it idles a bit under 1k, and does that for a while. But eventually the idle will creep up to 1.5-1.7k after I have been driving for a while. I have turned the fuel up. Could this just be from thermal expansion of the fuel screw, or can there be another cause?
Reply #1April 03, 2008, 09:39:25 am
truckinwagen
  • 1895
Fast idle
« Reply #1 on: April 03, 2008, 09:39:25 am »
my car does the same thing,
I think its because the motor naturally idles slower when cold.
if you adjust your idle cold it will creep up when hot.
if you adjust your idle hot it will be too low cold.
83 Opel Kadett Diesel
Reply #2April 03, 2008, 10:30:43 am
Op-Ivy
  • 513
Fast idle
« Reply #2 on: April 03, 2008, 10:30:43 am »
Mine does the same thing. Not as drastic however. 900 at idle 1050ish maybe otherwise. I have to bring it down some.
Reply #3April 03, 2008, 10:40:51 am
Fast idle
« Reply #3 on: April 03, 2008, 10:40:51 am »
yeah, mine idles at about 830 cold and sometimes as high as 1100 hot.
I didn't have this problem with my first pump 'till I turned the fuel up but all my pumps since then do that stock and it just gets worse when the fuel's turned up.
This is with a 1.6NA
Reply #4April 03, 2008, 10:40:54 am
Fast idle
« Reply #4 on: April 03, 2008, 10:40:54 am »
K, I'll adjust hot, then just use my hand throttle when cold if I have to. I don't remember if my IDI did it, but if it did, it wasn't as much, but I don't think the fuel had been turned up on it either.
Reply #5April 03, 2008, 02:18:08 pm
Fast idle
« Reply #5 on: April 03, 2008, 02:18:08 pm »
Quote from: "jimfoo"
thats what i'd say.  i've adjusted my cold start idle to be around 1000 and pushed in its about 900 to avoid the really rough idle.
Reply #6April 03, 2008, 07:54:49 pm
Op-Ivy
  • 513
Fast idle
« Reply #6 on: April 03, 2008, 07:54:49 pm »
Yea I just keep the idle low when cold and pull out the cold start a tad. Then when it warms up a bit it's normal.
Reply #7April 03, 2008, 08:04:11 pm
Fast idle
« Reply #7 on: April 03, 2008, 08:04:11 pm »
Quote from: "Op-Ivy"
Well, if I actually had the cold start hooked up...., but I don't.
