Author Topic: I think I fried my tach - can I tell for sure?  (Read 3907 times)
March 16, 2008, 08:00:34 pm
rallydiesel
  • 1880
« on: March 16, 2008, 08:00:34 pm »
The "W" terminal on my old alternator grounded against the alternator housing and fried the alternator and starter. I have a new alternator and starter and everything is great but my tach doesn't work. It worked before the short but doesn't anymore.
Anybody know what sort of numbers I should be seeing from the "w" terminal and could I test the tach by giving it 12V? If the tach is toast is there anything that can be replaced to fix it or do I need a new cluster?
1991 Jetta TD - sold :(
2001 Golf TDI - Son's
Reply #1March 16, 2008, 09:01:30 pm
« Reply #1 on: March 16, 2008, 09:01:30 pm »
Unfortunately we are talking about a frequency measuring system here so a voltmeter won't be of much help... you'd need an oscilloscope to see the waveform coming from the W terminal, and a frequency generator to test the tach.
If you have a multimeter with a frequency scale you might be able to detect the signal coming from the W terminal... never done it myself as I have a 'scope.  A voltmeter set to the AC setting might actually recognize the signal as well... never done it but it's worth trying now that I think of it.
Grounding the tach input should not have damaged it (although I suppose it might have gotten a voltage spike that did) so I'd be inclined to triple-check the wiring if you're convinced your newer alternator is in fact working... here's where your voltmeter will help you... got a good 12.5V-ish at the alternator with the engine off, that jumps a volt or more with the engine running ?
Failing that, part substitution is another way to go.
Reply #2March 16, 2008, 09:14:36 pm
rallydiesel
  • 1880
« Reply #2 on: March 16, 2008, 09:14:36 pm »
The alt is working as far as I can tell. Battery is 12.something with engine off and 13.something while running. I guess I will have to break out the old bentley and check the wiring diagrams.
